Topic: Sending multiple messages over CAN with sparkfun can bus shield (Read 3307 times) previous topic - next topic
Mozernz
Hi all
Complete newbie in terms of Arduino here.
I would like to send different can messages over my sparkfun can shield.
My can shield is for test purposes hooked up to another can sniffer i have.
I'm using the write example from the library an can also seeing the messages i sent on my can sniffer.
But when I'm adding a second message with different ID and data the code loops through it one time and then send again only one message... Please be kind to me I'm new to programming.. ;)
Code is below sends message1 for 10s and then message2 for 1s and then only message1 for the rest of the time. Why does it not loop trough everything again?
Code: [Select]
#include <Canbus.h>
#include <defaults.h>
#include <global.h>
#include <mcp2515.h>
#include <mcp2515_defs.h>
//********************************Setup Loop*********************************//
  Serial.println("CAN Write - Testing transmission of CAN Bus messages");
  if(Canbus.init(CANSPEED_500))  //Initialise MCP2515 CAN controller at the specified speed
    Serial.println("CAN Init ok");
    Serial.println("Can't init CAN");
//********************************Main Loop*********************************//
tCAN message1;
        message1.id = 0x1A6; //formatted in HEX
        message1.header.rtr = 0;
        message1.header.length = 7; //formatted in DEC
        message1.data[0] = 0x02;
message1.data[1] = 0x8b;
message1.data[2] = 0xFF;
message1.data[3] = 0x67; //formatted in HEX
message1.data[4] = 0x00;
message1.data[5] = 0x00;
message1.data[6] = 0x1F;
tCAN message2;
        message2.id = 0x18F; //formatted in HEX
        message2.header.rtr = 0;
        message2.header.length = 8; //formatted in DEC
        message2.data[0] = 0x02;
  message2.data[1] = 0x8b;
  message2.data[2] = 0xFF;
  message2.data[3] = 0x67; //formatted in HEX
  message2.data[4] = 0x01;
  message2.data[5] = 0x8D;
  message2.data[6] = 0x1F;
  message2.data[7] = 0x1F;
mcp2515_bit_modify(CANCTRL, (1<<REQOP2)|(1<<REQOP1)|(1<<REQOP0), 0);
mcp2515_send_message(&message1);
delay(10000);
mcp2515_send_message(&message2);
Thanks all!
MorganS
Quote
Code: [Select]
mcp2515_send_message(&message);
Are you sure that compiles? You haven't defined message anywhere in your code. Perhaps you meant message1?
You also have a 10-second delay. Did you wait 10 seconds?
"The problem is in the code you didn't post."
Mozernz
Sorry message1 is message in my code. Yes it compiles and i also see the messages in via my can sniffer. The 10s are just there to see which messages is broadcasted. But like i said i goes through the code once and then only sends message (no message2 again) for the rest of the time after the delays... Don't know why
MorganS
You say your code is different to the code posted above. We aren't going to spend any more time debugging that code. Please post the actual code you're using. Use the CTRL-T autoformat first.
Mozernz
Hi morgan code is:
Code: [Select]
#include <Canbus.h>
#include <global.h>
tCAN message1;
tCAN message2;
delay(10000);
Found a solution to software reset and start the loop again this works.
Code: [Select]
tCAN message;
        message.id = 0x1A6; //formatted in HEX
        message.header.rtr = 0;
        message.header.length = 7; //formatted in DEC
        message.data[0] = 0x02;
message.data[1] = 0x8b;
message.data[2] = 0xFF;
message.data[3] = 0x67; //formatted in HEX
message.data[4] = 0x00;
message.data[5] = 0x00;
message.data[6] = 0x1F;
tCAN message2;
Serial.print(message.id);
delay(10);
Serial.print(message2.id);
delay(10);
software_Reset();
void software_Reset() // Restarts program from beginning but does not reset the peripherals and registers
asm volatile ("  jmp 0");
I think my problem has something to do with resetting the mcp2525.
Thanks
Mozernz
My problem is not solved... I only can send the first 3 messages with this code all other messages will be ignored.. I think it has something to do with the mcp2525? Anybody?
jtanner
I realise this thread is ooolllddddd..... but, I'm sure you have to
before EVERY message.  So...
mcp2515_send_message(&message3);
