Topic: TCP conecction with A7 GSM/GPRS/GPS (Read 8780 times) previous topic - next topic
JuanJoseJarChigui
Hello there, im a student trying to get a project done over here, ive tried a lot of things on this one, but its been imposible to solve it. im working to A7 Aithinker company, and had been able to send/recibe sms and calls, but then im triying to send a GET request to a web page, mine by the way, and it just doesnt work.
The connection is done:
AT+CIPSTART="TCP","192.254.182.188",80
CONNECT OK
OK
but then when i try to get the document i need this happens:
AT+CIPSEND=
GET /css/about-us.css HTTP/1.1
Host: 192.254.182.188:80
Connection: keep-alive
OK
+CIPRCV:431,HTTP/1.1 302 Found
Content-Type: text/html; charset=UTF-8
Content-Length: 211
Location: http://HTTP://190.102.192.66:8090/?dest_url=http:///css/about-us.css&msisdn=573016322960
Cache-Control: no-cache
Connection: Close
<html><head><title>302 Found</title></head><body><h1>302 Found</h1><p>The document has moved <a href="http://HTTP://190.102.192.66:8090/?dest_url=http:///css/about-us.css&msisdn=573016322960">here</a></p></body></html>
it hapens the same with every webpage i try, and by the way ive tried to set a server on my computer, unloked the port, and when i try to connec to it from my A7 it connects!!!!! and the port that is listening says: > New Client: 177.252.245.166
but then i try to send info, and it just colapse COMMAND NO RESPONSE
I really need help over here, im a young developer still is one of the big homies willing to help this pour soul?
JohnMattias
What is wrong with this code for A7 Elecrow shield ?
 * Created by Island
 * Modified by keen
 * Date: 17/03/2017
#define S1debug true
#define S_debug true
  Serial1.begin(115200);   // the GPRS baud rate
  Serial.begin(115200);    // the GPRS baud rate
 * After start up the program, you can using terminal to connect the serial of gprs shield,
 * If you input 't' in the terminal, the program will execute SendTextMessage(), it will show how to send a sms message,
 * If input 'd' in the terminal, it will execute DialVoiceCall(), etc.
  if (Serial.available()){
    switch(Serial.read()){
     case 't':
       SendTextMessage();
     case 'd':
       DialVoiceCall();
     case 'h':
       SubmitHttpRequest();
     case 'q':
       GetSignalQuality();
   RecData();
 * SendTextMessage()
 * This function is to send a sms message
void SendTextMessage()
  SendData("",2000,S1debug);
  SendData("AT+CMGF=1",2000,S1debug);//Because we want to send the SMS in text mode
  delay(100);
  SendData("AT+CMGS=+46706015317",2000,S1debug);//send sms message, be careful need to add a country code before the cellphone number
  delay(100);
  SendData("GSM test message!",2000,S1debug);//the content of the message
  delay(100);
  Serial1.println((char)26);//the ASCII code of the ctrl+z is 26
  delay(100);
 * DialVoiceCall
 * This function is to dial a voice call
void DialVoiceCall()
   SendData("AT+SNFS=0",2000,S1debug);
   delay(100);
   SendData("ATD+86137xxxxxx",2000,S1debug);// "ATD+86137xxxxxxxx"dial the number
   delay(100);
 * SubmitHttpRequest()
 * This function is submit a HTTP request
 * attention:the time of delay is very important, it must be set enough
void SubmitHttpRequest(){
   SendData("AT+CREG?",1000,S1debug); //Query network registration
   delay(100);
   SendData("AT+CGATT=1",2000,S1debug);
   delay(100);
   SendData("AT+CGDCONT=1,\"IP\",\"CMNET\"",2000,S1debug);//setting PDP parameter
   delay(100);
   SendData("AT+CGACT=1,1",2000,S1debug); //Activate PDP, open Internet service
   delay(100);
   SendData("AT+CIPSTART=\"TCP\",\"www.baidu.com\",80",5000,S1debug); //Establish TCP connection
   delay(100);
   SendData("AT+CIPSEND=10,\"asdfg12345\"",2000,S1debug); //Send string "asdfg12345" and the length of string is 10
   delay(100);
   SendData("AT+CIPCLOSE",2000,S1debug);     //Close TCP
   delay(100);
void GetSignalQuality(){
     Serial_Print("Getting the sinal quality...",S_debug);
     SendData("AT+CSQ",1000,S1debug);
     Serial_Print("Tips:+CSQ: XX,QQ : It means the Signal Quality poorly when the XX less then 10!",S_debug);
void SendData(String command, const int timeout, boolean debug){
    String response = "";
    Serial1.println(command);
    delay(5);
    if(debug){
    long int time = millis();
    while( (time+timeout) > millis()){
      while(Serial1.available()){
        response += char(Serial1.read());
      Serial.print(response);
void Serial_Print(String data, boolean debug){
  if(debug){
    Serial.println(data);
void RecData(){
apzip
Similar problem with Ai_Thinker A9G (V02.02.20180825R);
Using AT+GETHTTP command to send/receive data from my php server, receiving only a part of response header with 200 code but can not get body of server response.
AT+HTTPGET="http://xxxxx.com/iot/api.php?sensor=100"
OK
HTTP/1.1  200  OK
Server: nginx/1.16.0
Date: Wed, 08 Ja
How can I retrieve full header and body response of the server?
Note: Normally server return echo of the value -json- and print on screen.
