Topic: Matlab Arduino serial comminucation (Read 531 times) previous topic - next topic
Sidi
Hello, i need my arduino Mega 2560 to read a value from matlab by serial communication.
I use these codes :
for the arduino IDE
int f;
boolean Communication =1;
  pinMode (11, OUTPUT) ;
  pinMode (12, OUTPUT) ;
  pinMode (5, OUTPUT) ;
  pinMode (2, OUTPUT) ;
  pinMode (6, OUTPUT) ;
  pinMode (7, OUTPUT) ;
 if (Serial.available()>0)
  freq = Serial.parseInt() ;
  if (Communication)
    if (f>=1000)
           float icr=(15989332/(1*f)) ;
           TCCR1A = 0xE2 ;
           TCCR1B = 0b00011001 ;
           ICR1  = icr ;
           OCR1A = icr/2-1 ;
           OCR1B = icr/2-1 ;
           TCNT1 = 0x0000 ;
           TCCR3A = 0xE2 ;
           TCCR3B = 0b00011001 ;
           ICR3  = icr ;
           OCR3A = icr/2-1 ;
           OCR3B = icr/2-1 ;
           TCNT3 = 0x0000 ;
           TCCR4A = 0xE2 ;
           TCCR4B = 0b00011001 ;
           ICR4  = icr ;
           OCR4A = icr/2-1 ;
           OCR4B = icr/2-1 ;
           TCNT4 = 0x0000 ;
           float icr=(15989332/(8*f));
           TCCR1A = 0xE2 ;
           TCCR1B = 0b00011010 ;
           ICR1  = icr ;
           OCR1A = icr/2-1 ;
           OCR1B = icr/2-1 ;
           TCNT1 = 0x0000 ;
           TCCR3A = 0xE2 ;
           TCCR3B = 0b00011010 ;
           ICR3  = icr;
           OCR3A = icr/2-1 ;
           OCR3B = icr/2-1 ;
           TCNT3 = 0x0000 ;
           TCCR4A = 0xE2 ;
           TCCR4B = 0b00011010 ;
           ICR4  = icr ;
           OCR4A = icr/2-1 ;
           OCR4B = icr/2-1 ;
           TCNT4 = 0x0000 ;
        Communication =0 ;
and for Matlab
clear all
clc
freq= 100; % frequency value
arduino=serial('COM8','Baud',9600); % create serial communication object on port COM8
fopen(arduino); % initiate arduino communication
fprintf(arduino,freq); % send  variable content to arduino
fclose(arduino); % end communication with arduino
but it doesn't work for me, i mean when i execute the programms, i don't get a PWM signal with the inputted frequency (freq).
i need help.
Thanks.
Robin2
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
Keep in mind that serial data arrives very slowly by Arduino standards even at 500,000 baud.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Sidi
thank you, this was very helpful. Indeed, i have to consider the time that matlab takes to create the communication with arduion, it's about 1 second for open. Thanks again, i used your function, recvWithEndMarker.
