Topic: Sketches not uploading (Read 61733 times) previous topic - next topic
TheWT
Hey guys, i just got an arduino uno and decided to upload a blink sketch to it in order to test it out. I am running the 2017 MacBook pro, and plugged in the arduino with a USB-C adapter. When i clicked upload, i got the following error:
Arduino: 1.8.5 (Mac OS X), Board: "Arduino/Genuino Uno"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "COM1": No such file or directory
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
I tried selecting the different ports on my computer, but they are all USB-C, and i used a USB-C adapter.
Does anyone know how to set this up so it works?
Thanks!
DrAzzy
Select the appropriate port from the Tools -> Port menu.
The fact that it's trying to use COM1 (the "default" port, which only exists on windows systems) indicates that you have never selected a port. If the ports menu is greyed out, you have driver problems or are using a bad cable (there's been a plague of defective USB cables recently)
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
TheWT
Ive tried both ports and neither work. Here is a screenshot of the available options:
Lehlogonolo
Hi Team.
I have problems with uploading my code on the arduino uno when i try to it gives me these error saying no sync.
Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Uno"
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x32
Thanks as your help will be appreciated.
anbu123
Are you using arduino TX and Rx pins? What project?
TJH
Just put Arduino SW on new computer. Had same issue until i realised that i had to change board type to one i was using. Then it worked as before.
JieSheng
Hey, you should try check your Serial Port in DEVICE MANAGER.
I was facing the same problem but once i opened device manager, it became available to select Port from the Arduino software.
sahiltareja
Hello,
I am having this error while uploading my sketch, Please help me out
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd7
sterretje
Hello,
Which OS? Correct serial port selected? Correct board selected?  What does device manager say (or the alternative in linux/mac say?
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
shaik123
Elnazt
Hello
I am working with uno3 and  ubuntu,  when i whant to upload my program i have this warning :
Arduino: 1.8.5 (Linux), Board: "Arduino/Genuino Uno" Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes. Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes. avrdude: ser_open(): can't open device "/dev/ttyACM0": Permission denied Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions. This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences
  can anyone help me?
Thanks.
DrAzzy
Hello
  can anyone help me?
Thanks.
Don't hijack threads with unrelated problems.
Your issue is that you have the wrong port selected, and/or your user is not a member of the dialout group, and hence does not have access to the serial ports (by default, users do not have permissions to access serial ports)
Elnazt
Hi  DrAzzy,  but my user is a member of  dialout group and i have selected  correct port (/dev/ttyACM0)!!!
 but again i have the same error :/
JEdS2008
I need help. I tried many things but my sketch isn't uploading. Also just saying I use mac.
10_Preetham_Krishna
Arduino: 1.8.9 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd2
\\so what should i do//
