Topic: Sketches not uploading (Read 61704 times) previous topic - next topic
isaac_kendall
Changing the cable solved it for me. My port was not showing up.
Saifullah2001
can you help me?
Arduino: 1.8.9 (Linux), Board: "Arduino/Genuino Uno"
Sketch uses 962 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "/dev/ttyACM0": Permission denied
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
sterretje
can you help me?
Looks like you have to add yourself to the dialout group.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
Usama_Ameen
I'm having issues in connecting my Arduino mega 2560 on windows 10. it connected once, when I uploaded a check program on it, now that program is running but it is not recognized by os. port option is grey and unusable. Tx, Rx led's are on while I'm not using them. I supplied 12 volts power and it's IC just burnt my finger instantly so I unplugged it and using USB to operate right now. please help me to solve my issue. Thanks
sterretje
Which IC got hot?
racpra16
Can you share the picture of your IC getting hot on Arduino Mega 2560
┗(•ˇ_ˇ•)―→ Member of the Ardunio customer service team
( ━☞´◔‿ゝ◔`)━☞ Contact us through https://bit.ly/2xxu1le
kitotek
#21
Nov 24, 2019, 03:09 am Last Edit: Nov 24, 2019, 03:41 am by kitotek
I have the same problem and I have tried everything including wiping and rebooting my computer (it needed to be wiped anyway) then I used a whole different board and different computer and it is still broken.
please give some actually helpful advice (not this)
Are you using arduino TX and Rx pins? What project?
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1610 bytes (4%) of program storage space. Maximum is 32256 bytes.
Global variables use 184 bytes (8%) of dynamic memory, leaving 1864 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "\\.\COM5": Access is denied.
        v
        what does it mean "Access is denied"
        what is denying my access!
vw2
Problem uploading:
Using Arduino example "servo"
set sketch: serial monitor and plotter COM 1, board: Arduino/Genuine Uno
using Arduino Uno board with Parallax shield.
Need help.
Thanks
Monti
ballscrewbob
vw2
Could you take a few moments to Learn How To Use The Forum.
It will help you get the best out of the forum as a whole.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
sterretje
Problem uploading:
Need help.
Thanks
Monti
COM1 is hardly ever the correct port. What does Windows device manager say under the ports section when you connect the board.
