Topic: [Solvd] Can't upload sketches on Due: bossac: extra arguments found (Read 1 time) previous topic - next topic
patran
I have a problem that I wasnt able to solve so far. Since today I cant upload any sketches to my Arduino Due with the web editor. The Error message:
Flashing with command:/home/porklemon/.arduino-create/arduino/bossac/1.6.1-arduino/bossac --port=ttyACM0 -U false -e -w {upload.verify} -b /tmp/arduino-create-agent667841717/sketch_oct3a.bin -R
I have this problem on Linux and Windows, so I assume the problem isn't my fault.
I'm able to upload the sketch manually over the console when I remove the {upload.verify} part.
Any idea how to fix this if this isnt a serverside error?
pert
I don't think there's anything you can do. Just use the standard Arduino IDE for now and check back with the Arduino Web Editor occasionally to see if they've gotten it fixed yet.
matteosuppo
Hello, could you please try again and let us know if the error is still there?
http://www.google.it
00alis
We tested again and this issue should be definitively solved
patrickADI
Hello,
this issue seems to be back again or isn't solved. I'm using the Arduino web editor, Arduino DUE (Programming port) and already the basic blink example sketch fails to upload. I also tried Firefox and Chrome, including reinstall of the plugin, still no success:
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/508095940/build/core/core.a /tmp/508095940/build/core/wiring_digital.c.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/508095940/build/core/core.a /tmp/508095940/build/core/wiring_pulse.cpp.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/508095940/build/core/core.a /tmp/508095940/build/core/wiring_pulse_asm.S.o
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-ar rcs /tmp/508095940/build/core/core.a /tmp/508095940/build/core/wiring_shift.c.o
Archiving built core (caching) in: /tmp/core/core_arduino_sam_arduino_due_x_dbg_6e18a96b2f6e1a733d0d079e7d8e383a.a
Linking everything together...
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-gcc -mcpu=cortex-m3 -mthumb -Os -Wl,--gc-sections -T/home/builder/.arduino15/packages/arduino/hardware/sam/1.6.12/variants/arduino_due_x/linker_scripts/gcc/flash.ld -Wl,-Map,/tmp/508095940/build/Blink.ino.map -o /tmp/508095940/build/Blink.ino.elf -L/tmp/508095940/build -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--start-group -u _sbrk -u link -u _close -u _fstat -u _isatty -u _lseek -u _read -u _write -u _exit -u kill -u _getpid /tmp/508095940/build/sketch/Blink.ino.cpp.o /tmp/508095940/build/core/variant.cpp.o /home/builder/.arduino15/packages/arduino/hardware/sam/1.6.12/variants/arduino_due_x/libsam_sam3x8e_gcc_rel.a /tmp/508095940/build/core/core.a -Wl,--end-group -lm -lgcc
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-objcopy -O binary /tmp/508095940/build/Blink.ino.elf /tmp/508095940/build/Blink.ino.bin
/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-size -A /tmp/508095940/build/Blink.ino.elf
Sketch uses 10692 bytes (2%) of program storage space. Maximum is 524288 bytes.
Programming with: Serial
Restarting in bootloader mode
Get port list before reset
[COM5]
Touching port COM5 at 1200bps
Set DTR off
Flashing with command:C:/Users/pwilhelm/.arduino-create/arduino/bossac/1.8.0-48-gb176eee/bossac.exe -i -d --port=COM5 -U false -e -w -b C:/Users/pwilhelm/AppData/Local/Temp/arduino-create-agent420942292/Blink.bin -R
Try 'bossac -h' or 'bossac --help' for more information
pert
What you are experiencing is actually a new issue that is a bit different from the original one reported in this thread, even though it results in the same error message. I have reproduced the issue and notified the Arduino Web Editor team about it. Someone will post on this thread once it has been resolved.
Thanks for reporting this patrickADI!
Marc Lantelme
ballscrewbob
@Marc Lantelme
Does your problem relate to a DUE or a different board ?
Please read the sticky posts at the top of this section and add more details please as a "mee too" question will not get much help without it.
Bob.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
