Topic: Blinking LED at 40HZ square wave  (Read 1 time) previous topic - next topic
3DDD
Hi Everyone,
I am trying to make a LED blink at 40HZ with square wave and I was wondering if I have the right code. Any help will be greatly appreciated.
Thanks in advance :)
int PIN = 13;
  pinMode(PIN, OUTPUT);
  int state = 0;
  while(1) {
    if(state == 0) {
      digitalWrite(PIN, LOW);
      state = 1;
    else {
      digitalWrite(PIN, HIGH);
      state = 0;
    delay(12.5);
Wawa
delay(12.5); // won't work. Integers only.
can use
delayMicroseconds(12500);
Leo..
Code: [Select]
int PIN = 13;
larryd
tone(pin, frequency)
Try:
tone(13, 40);
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
3DDD
Hi Leo and Larryd, I appreciate the help, thanks alot !
Larryd, is there a difference in the light output with this code when compared to the code Leo (Wawa) posted ? If so, where do I add this code to in order to try it ?
larryd
#4
Oct 30, 2017, 09:21 pm Last Edit: Oct 30, 2017, 09:23 pm by larryd
Light o/p will be the same.
Code: [Select]
    tone(13, 40);
No technical PMs.
Wawa
A human can't see a LED blinking at 40Hz.
Too fast. It will appear dim.
The frequency has to be less than ~10Hz for "blinking".
delay() is blocking code.
Try to understand the non-blocking "BlinkWithoutDelay" sketch in the examples of the IDE.
Both codes are  50% of the time fully on and 50% of the time off, so the same brightness.
If you want to change the brightness of an LED, use analogWrite() on a PWM pin.
That changes the on/off time. Humans see that as dimming.
Leo..
