Here is what is seen on serial monitor:
Initialize buffers
CAN device ready
Start address claim for device 0
202 : Pri:6 PGN:60928 Source:22 Dest:255 Len:8 Data:69,B6,1,FF,0,82,96,C0
2703 : Pri:6 PGN:130312 Source:22 Dest:255 Len:8 Data:1,1,4,7D,73,FF,FF,FF
2703 : Pri:6 PGN:130311 Source:22 Dest:255 Len:8 Data:1,44,7D,73,FF,7F,FF,FF
2705 : Pri:6 PGN:130310 Source:22 Dest:255 Len:8 Data:1,C1,70,FF,FF,FF,FF,FF
that goes on until
45220 : Pri:6 PGN:130311 Source:22 Dest:255 Len:8 Data:1,44,7D,73,FF,7F,FF,FF
PGN 130310 send failed
45224 : Pri:6 PGN:130310 Source:22 Dest:255 Len:8 Data:1,C1,70,FF,FF,FF,FF,FF
PGN 130312 send failed
47721 : Pri:6 PGN:130312 Source:22 Dest:255 Len:8 Data:1,1,4,7D,73,FF,FF,FF
PGN 130311 send failed
47721 : Pri:6 PGN:130311 Source:22 Dest:255 Len:8 Data:1,44,7D,73,FF,7F,FF,FF
47729 : Pri:6 PGN:130310 Source:22 Dest:255 Len:8 Data:1,C1,70,FF,FF,FF,FF,FF
It makes no difference if arduino is connected to bus with display or not. So far I have tried only with one arduno. I have two arduinos and available so I could add another to the bus and see what it sees an the bus. Would Actisense listener be the sketch to download to the other arduino? So far I only have tested hardware with one arduino with this test program:
http://copperhilltech.com/blog/app-note-testing-arduino-due-with-2-can-bus-breakout-boards/ and it works and also have been able to read depth sounder from the bus.
