Hello Timo,
First I thank you verry much for your work on NMEA2000.
Yes, teensy looks very good, I would rather take teensy today.
But I use with the DUE the quadinput for an incremental poti, one of the two analog outputs and the Yun-Shield to transfer programs wireless.
I tested with two DUE, both have the same problem.
- First I had the fatal error: can_common.h: No such file or directory
- Then test with clean environment, all libraries deleted,
only due_can-master, NMEA2000_due-master, NMEA2000-master;
fatal error was gone even though the libraries were the same.
But can does not send.
