Hi Timo,
I am a beginner in Arduino programming!
I would like to send fuel rate in the nmea 2000 bus.
As a first step I modified your sketch" temperature monitor" to read the fuel rate with Actisense NMEA Reader, but tells me error to the SetN2kEngineDynamicParam line "fuelRate was not declared in this scope"
This is the sketch. Can you help me! Thank you!
// Demo: NMEA2000 library. Send fuel rate data to the bus.
#include <Arduino.h>
#include <NMEA2000_CAN.h> // This will automatically choose right CAN library and create suitable NMEA2000 object
#include <N2kMessages.h>
// List here messages your device will transmit.
const unsigned long TransmitMessages[] PROGMEM={127489L,0};
// Set Product information
NMEA2000.SetProductInformation("00000002", // Manufacturer's Model serial code
100, // Manufacturer's product code
"Simple fuel rate monitor", // Manufacturer's Model ID
"1.1.0.22 (2016-12-31)", // Manufacturer's Software version code
"1.1.0.0 (2016-12-31)" // Manufacturer's Model version
// Set device information
NMEA2000.SetDeviceInformation(1, // Unique number. Use e.g. Serial number.
160, // Device function=FLOW. See codes on
http://www.nmea.org/Assets/20120726%20nmea%202000%20class%20&%20function%20codes%20v%202.00.pdf 75, // Device class=Sensor Communication interface. See codes on http://www.nmea.org/Assets/20120726%20nmea%202000%20class%20&%20function%20codes%20v%202.00.pdf
2046 // Just choosen free from code list on
http://www.nmea.org/Assets/20121020%20nmea%202000%20registration%20list.pdf );
// Uncomment 2 rows below to see, what device will send to bus. Use e.g. OpenSkipper or Actisense NMEA Reader
NMEA2000.SetForwardStream(&Serial);
// If you want to use simple ascii monitor like Arduino Serial Monitor, uncomment next line
//NMEA2000.SetForwardType(tNMEA2000::fwdt_Text); // Show in clear text. Leave uncommented for default Actisense format.
// If you also want to see all traffic on the bus use N2km_ListenAndNode instead of N2km_NodeOnly below
NMEA2000.SetMode(tNMEA2000::N2km_NodeOnly,23);
NMEA2000.SetDebugMode(tNMEA2000::dm_Actisense); // Uncomment this, so you can test code without CAN bus chips on Arduino Mega
//NMEA2000.EnableForward(false);
NMEA2000.ExtendTransmitMessages(TransmitMessages);
NMEA2000.Open();
SendN2kFuelRate();
NMEA2000.ParseMessages();
double ReadFuelRate() {
return 30; // Read here the measured flowrate e.g. from analog input
#define FuelRateUpdatePeriod 1000
void SendN2kFuelRate() {
static unsigned long FuelRateUpdated = millis();
tN2kMsg N2kMsg;
if ( FuelRateUpdated + FuelRateUpdatePeriod < millis() ) {
SetN2kEngineDynamicParam(N2kMsg,0,N2kDoubleNA,N2kDoubleNA,N2kDoubleNA,N2kDoubleNA,FuelRate,N2kDoubleNA);
NMEA2000.SendMsg(N2kMsg);
