Topic: NMEA 2000 Shield (Read 404092 times) previous topic - next topic
kenobiben
NMEA2000.SendProductInformation();
Now is working and MFD display it
Thanks a lot
mamasso30
What PGN's are included in the library? I would like to send the fuel flow through the PGN 127489 (Fuel rate) to a NMEA 2000 network with Garmin MFD's.
Regards
timolappalainen
Please check N2kMessages.h function SetN2kPGN127489 or it's alias SetN2kEngineDynamicParam
hirppa10
#708
Apr 04, 2019, 03:37 pm Last Edit: Apr 05, 2019, 01:31 pm by hirppa10
Has anyone managed to add esp8266 board to create wifi hotspot and upload all nmea2000 data to wifi? This way the data could be read on mobile or tablet with suitable app. Could this be integrated to Timo's library in way or other?
popeye_70
Hi all,
has anyone already built a fuel monitor?
I'm looking for suitable flow sensors for Arduino/Teensy 3.2, i need a couple because i have a diesel engine with also the return-to-tank.
And i'm not sure about measurement range needed (Yanmar says, at 3200rpm maximum fuel feed pump volume 6,5 litres/min).
timolappalainen
I tried, but not finished yet. I bought two FCH-Mini sensors http://www.tedcomp.se/produkter/flodesmatare/flodesmatare-fch-mini/ with 9000 p/l resolution. My engine fuel flow is between 0.25-0.6 l/m. One problem is with low RPM, when fuel flow is very small and due to pulsation pump. Both fuel lines seem to require good pulsation dampers, which I do not have yet. Without dampers fuel sensors seem to calculate back and forward causing false counting.
You can test you ranges simply:
- just open line between electric pump and engine and let it run fuel e.g. 10 seconds to some cup big enough and measure litres. Be careful, since free flow may be pretty big.
- open line between tank and return pipe and run engine freely for e.g. 30 sec and measure litres.
- repeat above for 3000 RPM.
With Teensy you can then measure both frequencies with FreqMeasureMulti https://github.com/PaulStoffregen/FreqMeasureMulti. Anyway you will need some low pass filtering for measurements.
maxik
How to connect esp32 to NMEA?
timolappalainen
- Download NMEA2000 and NMEA2000_esp32 libraries.
- Connect e.g. MCP2562 tranceiver TX (pin 1) to Esp32 GPIO 16 and RX (pin 4) to GPIO 4.
- Try example NMEA2000ToWiFiAsSeaSmart.
- If you use other pins, you have to add to NMEA2000ToWiFiAsSeaSmart.ino above line
#include <NMEA2000_CAN.h>
lines
Code: [Select]
#define ESP32_CAN_TX_PIN GPIO_NUM_xx
#define ESP32_CAN_RX_PIN GPIO_NUM_yy
popeye_70
Hi Timo
thank you for help, it looks like a nice sensor.
There is a version with built-in PT100, do you think is useful to compensate for density variations? Temperature before and after the engine can be quite different.
And yes, i fear that pulsation dampers are indispensable me too... :-(
timolappalainen
I prefer to do it somehow. I did not notice that version, so I have planned to use 1-wire sensors.
timolappalainen
Can I use module sach https://ru.aliexpress.com/item/MCP2515-CAN-Bus-TJA1050-SPI...
Yes, but then you need to force code to use mcp_can instead of internal can controllor. Also that seem to be with 8MHz clock, so you have to set that too.
And why you would like to use external controller, while there is build in CAN?
maxik
Only becose I have this board now but dont have MCP2562  :-)
timolappalainen
I prefer to use internal can and just tranceiver. Anyway there is some instructions on post 694 to force mcp_can and clock.
