Topic: MKR 1000 OTA (Read 1 time) previous topic - next topic
testpresta2
I have successfully run the Wifi101OTA example, which comes with Wifi101OTA Library.
The Serial Monitor displays my MKR1000 ip address, RSSI and SSID.
I am working with Arduino IDE on Mac OS X (latest version)
I only see Serial Ports on Tools>Port menu.
According to several tutorials, i should see an entry in this menu with Network ports.
I have wait several minutes i did not remember what i did and then i have seen my arduino in network ports entry. I have closed at relaunch arduino ide and i did never managed to see again this entry
Do you know where can come from this problem ?
Thanks
sandeepmistry
Hi @testpresta2
Could you try to restart the IDE after loading a sketch that uses WiFi101OTA?
testpresta2
I have restarted the IDE after loading sample sketch. it is exactly the same...
Thanks
