Hallo so eine ähnliche Frage hatte ich schon mal gestellt aber mit einem anderen script, ich möchte das nur jede 2. LED angesprochen wird, da mein Abilight Programm mit 150 LEDs nicht zurecht kommt und sich alles nachzieht. Ich bin leider ein absoluter Noob wenns ums programmieren geht, daher hoffe ich mir kann hier jemand helfen.
Danke im Vorraus.
Grüße,
Thomas
Script:
LEDstream_FastLED
* Modified version of Adalight that uses the FastLED
* library (http://fastled.io) for driving led strips.
* http://github.com/dmadison/Adalight-FastLED
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU Lesser General Public License for more details.
* You should have received a copy of the GNU Lesser General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
// --- General Settings
static const uint16_t
Num_Leds = 150; // strip length
static const uint8_t
Led_Pin = 6, // Arduino data output pin
Brightness = 255; // maximum brightness
// --- FastLED Setings
#define LED_TYPE WS2812B // led strip type for FastLED
#define COLOR_ORDER GRB // color order for bitbang
// --- Serial Settings
static const unsigned long
SerialSpeed = 115200; // serial port speed
SerialTimeout = 150; // time before LEDs are shut off if no data (in seconds)
// --- Optional Settings (uncomment to add)
#define SERIAL_FLUSH // Serial buffer cleared on LED latch
//#define CLEAR_ON_START // LEDs are cleared on reset
//#define GROUND_PIN 10 // additional grounding pin (optional)
//#define CALIBRATE // sets all LEDs to the color of the first
// --- Debug Settings (uncomment to add)
//#define DEBUG_LED 13 // toggles the Arduino's built-in LED on header match
//#define DEBUG_FPS 8 // enables a pulse on LED latch
#include <FastLED.h>
CRGB leds[Num_Leds];
uint8_t * ledsRaw = (uint8_t *)leds;
// A 'magic word' (along with LED count & checksum) precedes each block
// of LED data; this assists the microcontroller in syncing up with the
// host-side software and properly issuing the latch (host I/O is
// likely buffered, making usleep() unreliable for latch). You may see
// an initial glitchy frame or two until the two come into alignment.
// The magic word can be whatever sequence you like, but each character
// should be unique, and frequent pixel values like 0 and 255 are
// avoided -- fewer false positives. The host software will need to
// generate a compatible header: immediately following the magic word
// are three bytes: a 16-bit count of the number of LEDs (high byte
// first) followed by a simple checksum value (high byte XOR low byte
// XOR 0x55). LED data follows, 3 bytes per LED, in order R, G, B,
// where 0 = off and 255 = max brightness.
static const uint8_t magic[] = {
'A','d','a'};
#define MAGICSIZE sizeof(magic)
// Check values are header byte # - 1, as they are indexed from 0
#define HICHECK (MAGICSIZE)
#define LOCHECK (MAGICSIZE + 1)
#define CHECKSUM (MAGICSIZE + 2)
enum processModes_t {Header, Data} mode = Header;
static int16_t
c;
static uint16_t
outPos;
static uint32_t
bytesRemaining;
static unsigned long
t,
lastByteTime,
lastAckTime;
// Debug macros initialized
#ifdef DEBUG_LED
#define ON 1
#define OFF 0
#define D_LED(x) do {digitalWrite(DEBUG_LED, x);} while(0)
#else
#define D_LED(x)
#endif
#ifdef DEBUG_FPS
#define D_FPS do {digitalWrite(DEBUG_FPS, HIGH); digitalWrite(DEBUG_FPS, LOW);} while (0)
#else
#define D_FPS
#endif
void setup(){
#ifdef GROUND_PIN
pinMode(GROUND_PIN, OUTPUT);
digitalWrite(GROUND_PIN, LOW);
#endif
#ifdef DEBUG_LED
pinMode(DEBUG_LED, OUTPUT);
digitalWrite(DEBUG_LED, LOW);
#endif
#ifdef DEBUG_FPS
pinMode(DEBUG_FPS, OUTPUT);
#endif
FastLED.addLeds<LED_TYPE, Led_Pin, COLOR_ORDER>(leds, Num_Leds);
FastLED.setBrightness(Brightness);
#ifdef CLEAR_ON_START
FastLED.show();
#endif
Serial.begin(SerialSpeed);
Serial.print("Ada\n"); // Send ACK string to host
lastByteTime = lastAckTime = millis(); // Set initial counters
void loop(){
adalight();
void adalight(){
t = millis(); // Save current time
// If there is new serial data
if((c = Serial.read()) >= 0){
lastByteTime = lastAckTime = t; // Reset timeout counters
switch(mode) {
case Header:
headerMode();
break;
case Data:
dataMode();
break;
else {
// No new data
timeouts();
void headerMode(){
static uint8_t
headPos,
hi, lo, chk;
if(headPos < MAGICSIZE){
// Check if magic word matches
if(c == magic[headPos]) {headPos++;}
else {headPos = 0;}
else{
// Magic word matches! Now verify checksum
switch(headPos){
case HICHECK:
hi = c;
headPos++;
break;
case LOCHECK:
lo = c;
headPos++;
break;
case CHECKSUM:
chk = c;
if(chk == (hi ^ lo ^ 0x55)) {
// Checksum looks valid. Get 16-bit LED count, add 1
// (# LEDs is always > 0) and multiply by 3 for R,G,B.
D_LED(ON);
bytesRemaining = 3L * (256L * (long)hi + (long)lo + 1L);
outPos = 0;
memset(leds, 0, Num_Leds * sizeof(struct CRGB));
mode = Data; // Proceed to latch wait mode
headPos = 0; // Reset header position regardless of checksum result
break;
void dataMode(){
// If LED data is not full
if (outPos < sizeof(leds)){
dataSet();
bytesRemaining--;
if(bytesRemaining == 0) {
// End of data -- issue latch:
mode = Header; // Begin next header search
FastLED.show();
D_FPS;
D_LED(OFF);
#ifdef SERIAL_FLUSH
serialFlush();
#endif
void dataSet(){
#ifdef CALIBRATE
if(outPos < 3)
ledsRaw[outPos++] = c;
else{
ledsRaw[outPos] = ledsRaw[outPos%3]; // Sets RGB data to first LED color
outPos++;
#else
ledsRaw[outPos++] = c; // Issue next byte
#endif
void timeouts(){
// No data received. If this persists, send an ACK packet
// to host once every second to alert it to our presence.
if((t - lastAckTime) > 1000) {
lastAckTime = t; // Reset counter
// If no data received for an extended time, turn off all LEDs.
if((t - lastByteTime) > SerialTimeout * 1000) {
memset(leds, 0, Num_Leds * sizeof(struct CRGB)); //filling Led array by zeroes
FastLED.show();
mode = Header;
lastByteTime = t; // Reset counter
void serialFlush(){
while(Serial.available() > 0) {
byte r = Serial.read();
