Topic: USBHost library constantly updating? (Read 480 times) previous topic - next topic
gratefulfrog
Hi!
I am running IDE 1.8.5 on linux.
I recently began using the Arduino Zero and installed the USBHost library.
Since then, several times per day an update notification appears. I update and it seems to update
When I look at the properties in my sketchbook/libraries folder I see that it is currently at version 1.0.5 but it still requests to update over and over again.
Anyone have any ideas on how to stop this annoyance?
Cheers,
Bob
pert
Isn't that annoying. This is a known bug that was reported 2 years ago:
https://github.com/arduino/Arduino/issues/4189
https://github.com/arduino/Arduino/issues/5283
but I have not ever been able to get the Arduino developers to take it seriously.
There is a workaround you'll find I explained in those issue reports but you can also just do File > Preferences > Check for updates on startup (uncheck) > OK. Of course then you also won't get legitimate notifications of updatable libraries and boards (or IDE versions if they ever get around to fixing that bug.
gratefulfrog
@pert thanks for the tip, but I do want the real updates...
And thanks for the pointer to the bug reports.. I added my 2 cents.
Cheers,
Bob
pert
Well if you want assistance with the other workaround to the problem I can provide it.
gratefulfrog
Sure, thanks!
I didn't realize that there was a work around that didn't handicap the IDE...
Thanks!
pert
  • File > Examples > USBHost > ADKTerminalTest (or any other example sketch of the library)
  • Sketch > Show Sketch Folder - this will open the example sketch folder
  • Navigate up two folder levels to the root of the USBHost library folder.
  • Open library.properties in a text editor.
  • Change the line:
Code: [Select]
name=USBHost
to:
Code: [Select]
name=USBHost (Arduino SAMD Boards)
  • Save the file
You will need to repeat that process anytime you update to a new version of Arduino SAMD Boards.
gratefulfrog
#6
Nov 13, 2017, 02:16 pm Last Edit: Nov 13, 2017, 02:19 pm by gratefulfrog
Thanks!
I did it but that hasn't changed anything... the IDE still constantly wants to update that particular library..
Thanks anyway!
