Topic: what resistor should I be using for these 12v 50mA momentary buttons for my Ar3 (Read 2026 times) previous topic - next topic
a18
what resistor should I be using for these 12v 50mA momentary buttons for my Arduino R3?
The 5 LED buttons will be outputting a High, Low value for Arduino R3 to recognize to control a Servo Motor.
Enviroment temperature:-25 to 85 degree
Relative humidity: 40 to 80 degree
Rating:DC12V, 50MA
Contact Resistance: less than 100ohms
Insulation resistance: more than 100ohms, DC250V/1MIN
Dielectric strength: AC250V 50HZ for 1 MIN
Electrically life:100,000 cycles
Mechanical life:100,000 cycles
Travel:0.25+or-0.1mm
Operating force:160+or-50GF
Dimensions: 12 x 12mm(L x W)
Color: Red, Green, Blue, White, Yellow
Mainly used in digital camera, industrial equipment, home appliances, etc.
Stable performance, safety and reliability
Package includes:
RED *1PCS new
White *1pcs new
Yellow *1pcs new
Green *1pcs new
Blue *1pcs new
1974 wellcraft boat with Johnson 90 hp 2 stroke outboard motor to fish on the Potomac River in Washington DC USA Capital.
a18
This is an example Arduino code to use the read the button and execute the servo motor when button is pressed.
const int IButton = 10;     //Idle speed button
pinMode(IButton, INPUT);
IBState = digitalRead(IButton); // read the state of the Idle pushbutton value
if (IBState == HIGH) { // run the Idle speed function
delay(250); // to debounce button
Idle(); // go to Idle function
My guess is I can use 10K ohm resistor as well as the Arduino R3 internal pull-up resistor too.
larryd
Rating:DC12V, 50MA
This could imply there is already a resistor in the switch, BUT you will have to prove this.
Are you going to be using 12v?
Show us a good schematic of your proposed circuit.
Show us a good image of your wiring.
e
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
a18
Rating:DC12V, 50MA
This could imply there is already a resistor in the switch, BUT you will have to prove this.Don't really know and I have not bought it yet -
Are you going to be using 12v? NO
e
