I share with you my Arduino Web Server V2.0 (Closed)
[url removed]
I first debuted my Arduino web server in January of 2011, its been serving you all for months and gained thousands of hits over the course of its service.
Sadly, I retired it after 5 months, it was getting a little old.
Thanks to everyone who provided me with help when I needed it and also to the many people who left comments on the site. XD
Here is the latest code from the site:
* This is a web server that allows you to host a fully functional html
* webpage on the World Wide Web.
* Initial coding was done with the help from the many people in the Arduino community.
* Thanks guys!!
* Arduino Setup: You need an Ethernet Shield SD, and and Arduino.
* Optionally pins 8 and 9 can be used for two LEDs that can indicate traffic.
* SD Card Setup: On the SD card, which must be formated as fat, you must have
* an HTML file with the file name of 'index.htm'. All file names on this card
* must be written in the old 8.3 file format. In other words, all files must be
* named with no more then 8 characters for the name, and 3 for the extension.
* Note: If you don't know HTML, a good place that I found useful was w3schools
* http://www.w3schools.com/html/html_examples.asp
#include <LiquidCrystal.h>
#include <SPI.h>
#include <SdFat.h>
#include <SdFatUtil.h>
#include <Ethernet.h>
#define BUFSIZ 128
#define greenLEDandBEEP 2
#define redLEDpin 3
boolean led2 = true;
int hits = 0; // Set the number of hits the hit counter will start at.
int units = 0;
int count = 0;
int photocellPin = 2;
int photocellReading;
LiquidCrystal lcd(4, 5, 6, 7, 8, 9);
//Local ethernet setup
byte mac[] = {
0x90, 0xA2, 0xDA, 0x00, 0x1C, 0x0E };
byte ip[] = {
192, 168, 1, 80 };
char rootFileName[] = "index.htm";
Server server(8080);
//SD card stuff
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
PgmPrint("error: ");
SerialPrintln_P(str);
if (card.errorCode()) {
PgmPrint("SD error: ");
Serial.print(card.errorCode(), HEX);
Serial.print(',');
Serial.println(card.errorData(), HEX);
while(1);
lcd.begin(16, 2);
lcd.print("Web Server v2.00");
lcd.setCursor(0, 1);
lcd.print("Hits:");
pinMode(greenLEDandBEEP, OUTPUT);
pinMode(redLEDpin, OUTPUT);
PgmPrint("Free RAM: ");
Serial.println(FreeRam());
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
if (!card.init(SPI_HALF_SPEED, 4)) error("card.init failed!");
if (!volume.init(&card)) error("vol.init failed!");
PgmPrint("Volume is FAT");
Serial.println(volume.fatType(),DEC);
Serial.println();
if (!root.openRoot(&volume)) error("openRoot failed");
PgmPrintln("Files found in root:");
root.ls(LS_DATE | LS_SIZE);
Serial.println();
PgmPrintln("Files found in all dirs:");
root.ls(LS_R);
Serial.println();
PgmPrintln("Done");
Ethernet.begin(mac, ip);
server.begin();
if(count >=500)
led2 = !led2;
digitalWrite(redLEDpin, led2);
count = 0;
count +=1;
char clientline[BUFSIZ];
char *filename;
int image = 0;
int index = 0;
Client client = server.available();
if (client) {
boolean current_line_is_blank = true;
index = 0;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (c != '\n' && c != '\r') {
clientline[index] = c;
index++;
if (index >= BUFSIZ)
index = BUFSIZ -1;
continue;
clientline[index] = 0;
filename = 0;
Serial.println(clientline);
if (strstr(clientline, "GET / ") != 0) {
filename = rootFileName;
if (strstr(clientline, "GET /") != 0) {
if (!filename) filename = clientline + 5;
(strstr(clientline, " HTTP"))[0] = 0;
Serial.println(filename);
if (! file.open(&root, filename, O_READ)) {
client.println("HTTP/1.1 404 Not Found");
client.println();
client.println("<h2>Error 404</h2>");
client.println("<s2>The file does not exist.<s2>");
client.println("");
break;
Serial.println("Opened!");
//File types
if (strstr(filename, ".htm") != 0)
else if (strstr(filename, ".css") != 0)
client.println("Content-Type: text/css");
else if (strstr(filename, ".png") != 0)
client.println("Content-Type: image/png");
else if (strstr(filename, ".jpg") != 0)
client.println("Content-Type: image/jpeg");
else if (strstr(filename, ".gif") != 0)
client.println("Content-Type: image/gif");
else if (strstr(filename, ".3gp") != 0)
client.println("Content-Type: video/mpeg");
else if (strstr(filename, ".pdf") != 0)
client.println("Content-Type: application/pdf");
else if (strstr(filename, ".js") != 0)
client.println("Content-Type: application/x-javascript");
else if (strstr(filename, ".xml") != 0)
client.println("Content-Type: application/xml");
client.println("Content-Type: text");
client.println();
int16_t c;
while ((c = file.read()) >= 0) {
//Serial.print((char)c); //Prints all HTML code to serial (For debuging)
client.print((char)c); //Prints all HTML code for web page
//Hit counter math
if(units >= 2)
hits ++;
units = 0;
units +=1;
//End hit counter math
//Print the hit counters and light value
lcd.setCursor(6, 1);
lcd.print(hits); //Print hits for LCD hit counter
client.print("<html><body>"); //HTML code starts here
client.print("<P align=\"center\">");
client.print("Hits since reset: <b>");
client.print(hits); //Print hits to client
client.print("</b><br>");
photocellReading = analogRead(photocellPin);
client.print("Light reading: ");
client.print(photocellReading); //Prints light reading to client
// A few threshholds
if (photocellReading < 10) {
client.print(" - Dark");
else if (photocellReading < 200) {
client.print(" - Dim");
else if (photocellReading < 500) {
client.print(" - Light");
else if (photocellReading < 800) {
client.print(" - Bright");
else {
client.print(" - Very bright");
client.print("</p></body></html>"); //HTML code ends here
//End hit counter and light value
file.close();
else {
client.println();
client.println("");
break;
digitalWrite(greenLEDandBEEP, HIGH);
delay(1);
digitalWrite(greenLEDandBEEP, LOW);
client.stop();
//The End /*
The display is a 16x2 LCD with blue EL back light, thats the HV driver board in the upper right corner. The SD card was rerouted out to the front for easy access. There was a later edition too, a photocell, cleverly hidden next to the LCD's glass frame.
Oh, and if you want to know how I made the case,
arduino.cc/forum/index.php/topic,51138.msg412259.html#msg412259I have also included a basic HTML site template below.
