Topic: Looking for a way to measure the fuel level for an RC car tank ! help ! (Read 3644 times) previous topic - next topic
Qdeathstar
What about mounting the tank on a scale, would solve the vibration issues?
A creaking creeping shadow
stiff against the freezing fog
glares at a tickless watch.
Time has failed him -- all things shall pass.
polymorph
If you use my dual 555 circuit with the RC smoothing network and measure the DC level, that may act to average out variations due to tank vibration.
I'm not sure how mounting the tank on a scale solves the vibration problem.
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
Qdeathstar
Well, I mean, of you measured the weight of the fuel, you wouldn't have to worry about froth... I hadn't considered g-forces in my intial post, however.
firashelou
Don't understand you question.   You open the tank fuel fill hole and glue in the potentiomenter.  Attached to the pot shaft is a 90deg elbow.  Attached to the other end of the elbow is a short rod.  Attached to the other end of the rod is a float.  All these items are scaled to the size of your tank.  You attach two wires to the pot and use a voltage divider to measure voltage.  That's how virtually all car fuel tanks are measured.  It's simple and accurate.
i meant my tank has a closing cap, do you mean i must place the pot inside the tank under the closing cap ?
Aiming for the unreachable !
superair78
https://superair78.wordpress.com/4-la-technique/4-1-les-sondes-de-mesures/4-1-2-realisation-dun-temoin-de-reserve-de-carburant-avec-un-arduino/
