Those adapters, in particular, have a fairly high failure rate. On the ones I've had, build quality was horrifyingly bad (among other things, the USB connector housing usually wasn't soldered down, leaving it vulnerable to fatigue damage to the solder joints on the usb connector from plugging+unplugging it). They also don't break out DTR so you can't use them to easily program an Arduino Pro Mini or similar if you ever get one of those.
I would be sure to get a better model for your replacements (get ones that look like what I linked above, the black ones with the switch - they should be like $1.50-$2 shipped from ebay/aliexpress/etc).
