Topic: auto refresh on browser ESP32 (Read 811 times) previous topic - next topic
havala4
Hello, I'm trying the ESP32 and DS18B20
scetch: https://github.com/espressif/arduino-esp32/issues/755
The serial line is autorefresh
Not a autorefresh on the page
Thank you
 *     Read multiple DS18B20 Dallas sensors in a task.
 *     For ESP32 by CelliesProjects 2017.
 *     Code adapted from https://www.pjrc.com/teensy/td_libs_OneWire.html
//#define SHOW_DALLAS_ERROR        // uncomment to show Dallas ( CRC ) errors on Serial.
#define ONEWIRE_PIN           5    // OneWire Dallas sensors are connected to this pin
#define MAX_NUMBER_OF_SENSORS 3    // maximum number of Dallas sensors
#include "OneWire.h"
#include <WiFi.h>
const char* ssid = "----------";
const char* password = "----------";
OneWire  ds( ONEWIRE_PIN );        // (a 4.7K pull-up resistor is necessary)
struct sensorStruct
  byte addr[8];
  float temp;
  String name;
} sensor[MAX_NUMBER_OF_SENSORS];
byte numberOfFoundSensors;
  Serial.begin( 115200 );
  Serial.println( "\n\nMultiple DS18B20 sensors as task ESP32 example." );
  Serial.printf( "Connecting to %s with password %s\n", ssid,  password );
  xTaskCreatePinnedToCore(
    tempTask,                       /* Function to implement the task */
    "tempTask ",                    /* Name of the task */
    4000,                           /* Stack size in words */
    NULL,                           /* Task input parameter */
    5,                              /* Priority of the task */
    NULL,                           /* Task handle. */
    1);                             /* Core where the task should run */
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  while ( WiFi.status() != WL_CONNECTED )
    vTaskDelay( 250 /portTICK_PERIOD_MS );
    Serial.print( "." );
  if ( numberOfFoundSensors )
    Serial.println( String( millis() / 1000.0 ) + " sec" );
    for ( byte thisSensor = 0; thisSensor < numberOfFoundSensors; thisSensor++ )
      Serial.println( sensor[thisSensor].name + ": " + String( sensor[thisSensor].temp / 16.0 ) + "°C" );
    Serial.println( "No Dallas sensors." );
  vTaskDelay( 500 / portTICK_PERIOD_MS );
void tempTask( void * pvParameters )
  numberOfFoundSensors = 0;
  byte currentAddr[8];
  while ( ds.search( currentAddr ) && numberOfFoundSensors < MAX_NUMBER_OF_SENSORS )
    //Serial.write( "Sensor "); Serial.print( counter ); Serial.print( ":" );
    for ( byte i = 0; i < 8; i++)
      //Serial.write(' ');
      //Serial.print( currentAddr, HEX );
      sensor[numberOfFoundSensors].addr = currentAddr;
    //sensor[numberOfFoundSensors].name = 'T ' + char( numberOfFoundSensors );
    numberOfFoundSensors++;
  Serial.printf( "%i Dallas sensors found.\n", numberOfFoundSensors );
  if ( !numberOfFoundSensors )
    vTaskDelete( NULL );
  /* main temptask loop */
  while (1)
    for ( byte thisSensor = 0; thisSensor < numberOfFoundSensors; thisSensor++)
      ds.reset();
      ds.select( sensor[thisSensor].addr );
      ds.write( 0x44, 0);        // start conversion, with parasite power off at the end
    vTaskDelay( 750 / portTICK_PERIOD_MS); //wait for conversion ready
      byte data[12];
      ds.reset();
      ds.write( 0xBE );         // Read Scratchpad
      //Serial.print( "Sensor " );Serial.print( thisSensor ); Serial.print("  Data = ");
      //Serial.println( present, HEX );
      //Serial.print(" ");
      for ( byte i = 0; i < 9; i++)
      { // we need 9 bytes
        data = ds.read(  );
        //Serial.print(data, HEX);
      //Serial.println();
      byte type_s;
      // the first ROM byte indicates which chip
      switch ( sensor[thisSensor].addr[0] )
        case 0x10:
          //Serial.println("  Chip = DS18S20");  // or old DS1820
          type_s = 1;
        case 0x28:
          //Serial.println("  Chip = DS18B20");
          type_s = 0;
        case 0x22:
          //Serial.println("  Chip = DS1822");
          type_s = 0;
        default:
#ifdef SHOW_DALLAS_ERROR
          Serial.println("Device is not a DS18x20 family device.");
#endif
          return;
      int16_t raw;
      if ( OneWire::crc8(data, 8) != data[8])
        // CRC of temperature reading indicates an error, so we print a error message and discard this reading
        Serial.print( millis() / 1000.0 ); Serial.print( " - CRC error from device " ); Serial.println( thisSensor );
#endif
        raw = (data[1] << 8) | data[0];
        if (type_s)
          raw = raw << 3; // 9 bit resolution default
          if (data[7] == 0x10)
            // "count remain" gives full 12 bit resolution
            raw = (raw & 0xFFF0) + 12 - data[6];
          byte cfg = (data[4] & 0x60);
          // at lower res, the low bits are undefined, so let's zero them
          if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
          else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
          else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
          //// default is 12 bit resolution, 750 ms conversion time
        sensor[thisSensor].temp = raw;
