Topic: Need of a code for time to frequency domain conversion (Read 975 times) previous topic - next topic
aravindaguru
hi,
   I am trying to display the geophone sensor(sm-24) output as equivalent frequency(numeric values, Ex:for 'x'v volt i need to display the 'x'hz frequency"),i am using arduino zero and i tried numerous codes available in forum but none could solve my problem.can anyone suggest a solution for my problem
artisticforge
hi,
Any voltage to frequency conversion will be device specific.
The manufacturer of the device and/or the vendor from who you purchased the geophone should be able to provide you with that information. You may have to contact the manufacturer for the information.
I am surprised that given the cost of geophone devices that a software library and conversion were not provided when you purchased it.
the only other way would be build the conversion table yourself.
This would require a calibration fixture into which the geophone may be mounted.
You then provide an external stimulus of a specific frequency to the calibration fixture and record the output voltage.  this would give you a crude conversion table.
this is probably not what you wanted to read but it is the best answer I am able to provide.
