Topic: Garbage when drawing level map (Read 671 times) previous topic - next topic
andylatham82
Nov 20, 2017, 11:14 am Last Edit: Nov 20, 2017, 11:20 am by andylatham82
Hi, I have a tile in my game defined as a char array in a header file called bitmaps.h:
Code: [Select]
const unsigned char floorTile[] PROGMEM = {
  // Width & Height:
  8, 8,
  // Frame 0:
  0xff, 0x81, 0x8d, 0x8d, 0x81, 0xa1, 0x83, 0xff,};
I have made a LevelMap class:
Code: [Select]
#include "Tile.cpp"
#include "Bitmaps.h"
class LevelMap {
  public:
    Tile tiles[2] = {Tile(NULL),Tile(floorTile)};
    const unsigned char tileMap[2][8][16] = {
      { // Level 0:
        {1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1},
        {1,0,0,0,0,0,1,1,1,0,0,0,0,0,0,1},
        {1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1}
      { // Level 1:
        {1,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1},
    LevelMap(int a) {
    Draw() {
      for (int i = 0; i < 8; i++) {
        for (int j = 0; j < 16; j++) {
          if (tileMap[0][i][j] > 0)
            tiles[1].Draw(j * 8 * 256, i * 8 * 256);
And I have made a Tile class:
Code: [Select]
#pragma once
#include "Sprite.cpp"
class Tile {
  public:
    Sprite sprite;
    unsigned char tileTexture[10];
    Tile(const unsigned char texture[]) {
      memcpy(tileTexture, texture, sizeof(tileTexture));
    void Update() {
      sprite.active = false;
      sprite.Update(true);
    void Draw(int posX, int posY) {
      sprite.Draw(posX, posY, tileTexture);
The idea is that the LevelMap has a tileMap array which details how the level should be drawn on the screen, using simple chars as an index. A separate array of Tiles is created, and cross-referencing the two arrays dictates which type of tile is drawn where.
For some reason, however, I'm not getting the tile artwork through. I get garbage organised in the shape of the level. So I can recognise the level structure on the screen, but the actual artwork isn't being used. Instead there are various letters shown.
I know my Sprite class works fine with the char array artwork because I use the same things for character art, and that all shows correctly. Also if I say:
Code: [Select]
sprite.Draw(posX, posY, floorTile)
I get the level art drawing correctly. So maybe there is something wrong with how I'm passing the char array around.
I hope I'm explaining this ok. And I appreciate any help anyone can offer! Thanks :)
andylatham82
I should explain that the reason I multiply my tile drawing positions by 256 is that all positions in my game are multiplied up to give a greater range of numbers, ignoring the lower 8 bits at draw time.
AWOL
Are you using PROGMEM methods to read the array data?
andylatham82
I wasn't aware that there are specific PROGMEM methods. However I have been reading character images from PROGMEM and displaying them on the screen without issue.
andylatham82
Here's my Sprite class. I use this for both character drawing and level tile drawing.
Code: [Select]
#include<Arduboy2.h>
#pragma once
class Sprite {
  public:
    Sprites sprites;
    // Sprite animation variables.
    unsigned int framesSinceAnimUpdate = 0; // Number of updates since last animation frame advance.
    unsigned int currentFrame = 0;          // Displayed frame.
    unsigned int animationLength = 6;       // Number of frames.
    unsigned int frameRate = 60;            // Sprite frame rate.
    unsigned int framesBetweenUpdates;      // Number of frames between sprite animation updates.
    unsigned int height = 16;
    unsigned int width = 16;
    bool active = true;
    Sprite() {
      // Calculate number of frames between animation updates.
      framesBetweenUpdates = round((1.0 / frameRate) * 100);
    void Update(bool sameState) {
      if (active) {
        // Advance the sprite animation frame.
        framesSinceAnimUpdate++;
        if (framesSinceAnimUpdate > framesBetweenUpdates){
          currentFrame = (currentFrame + 1) % animationLength;
        if (!sameState)
          currentFrame = 0;
    void Draw(int posX, int posY, const unsigned char bitmap[]) {
      sprites.drawSelfMasked(posX >> 8, posY >> 8, bitmap, currentFrame);
arduarn
Take AWOL's hint and research the access methods for data in flash memory. Start here:
http://www.atmel.com/webdoc/avrlibcreferencemanual/pgmspace.html
andylatham82
Hmmm, well I've now looked into these access methods and tried them out, but haven't had much luck.
Is this definitely the problem? I ask because if I remove the PROGMEM command entirely, I still can't get the correct result.
arduarn
It's definitely a problem, but may well not be the only problem.
Post your updated code - preferably all of it.
andylatham82
Here's all my code. It's split into several files so sorry if it's difficult to figure out. I've also got to post it in a couple of replies as there's a 9000 character limit! There are also some bits I have commented out while I'm trying to fix up the level art stuff.
PART 1:
Main code:
Code: [Select]
#include "Player.cpp"
#include "Constants.h"
#include "LevelMap.cpp"
#include "Tile.cpp"
Arduboy2 arduboy;
Player player1;
LevelMap levelMap = new LevelMap(1);
int gameState = 0;
bool buttonA = false;
bool buttonB = false;
bool buttonLeft = false;
bool buttonRight = false;
  arduboy.begin();
  arduboy.setFrameRate(60);
  arduboy.clear();
  player1.Reset();
  if (!arduboy.nextFrame()) // Check time for next frame.
    return;
  switch (gameState) {
    case 0: // Title screen.
      DrawTitleScreen();
      if (arduboy.pressed(A_BUTTON) and !buttonA) {
        gameState = 1;
        buttonA = true;
    case 1: // Gameplay.
      if (arduboy.pressed(RIGHT_BUTTON) and player1.velocityX < player1.velocityXMax) {
        player1.velocityX += player1.velocityStep;
        player1.directionX = 1;
      if (arduboy.pressed(LEFT_BUTTON) and player1.velocityX > -player1.velocityXMax) {
        player1.velocityX += -player1.velocityStep;
        player1.directionX = -1;
      // Jump:
        player1.velocityY = -3 * 214;
        buttonA = true;
      UpdateGameObjects();
      DrawGameObjects();
      // Reset game:
      if (arduboy.pressed(B_BUTTON) and !buttonB) {
        gameState = 0;
        player1.Reset();
        buttonB = true;
  if (arduboy.notPressed(A_BUTTON))
    buttonA = false;
  if (arduboy.notPressed(B_BUTTON))
    buttonB = false;
void UpdateGameObjects() {
  //player1.Update(levelMap);   // Update player.
void DrawGameObjects() {
  arduboy.clear();    // Clear the screen.
  levelMap.Draw();
  player1.Draw();     // Draw player.
  //arduboy.setCursor(0, 0);
  //arduboy.print();
  arduboy.display();  // Copy bitmap from frame buffer to display.
void DrawTitleScreen() {
  arduboy.setCursor(48, 28);
  arduboy.print("Sprite");
Bitmaps.h:
Code: [Select]
#pragma once
#include<Arduino.h>
// Player sprite.
const unsigned char playerRunRight[] PROGMEM = {
  // Width & Height:
  16, 16,
  // Frame 0:
  0x00, 0x00, 0x00, 0x00, 0x34, 0xfe, 0x8e, 0x34, 0x6, 0x36, 0x8e, 0x94, 0x60, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x2, 0x1e, 0xe6, 0xa3, 0xda, 0x83, 0xc4, 0xb8, 0x00, 0x00, 0x00, 0x00,
  // Frame 1:
  0x00, 0x00, 0x00, 0x00, 0x68, 0xf8, 0x1e, 0x68, 0xc, 0x6c, 0x1c, 0x24, 0xc0, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x2, 0xbf, 0xcd, 0xc6, 0xb4, 0x86, 0x89, 0xf1, 0x80, 0x00, 0x00, 0x00,
  // Frame 2:
  0x00, 0x00, 0x00, 0x10, 0x3a, 0xfc, 0x8c, 0x36, 0x6, 0x36, 0x8c, 0x9c, 0x60, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0xf0, 0xfc, 0x66, 0x23, 0x5a, 0x43, 0xc4, 0xe8, 0x70, 0x00, 0x00, 0x00,
  // Frame 3:
  0x00, 0x00, 0x00, 0xa, 0x1e, 0x7e, 0x46, 0x9b, 0x3, 0x9b, 0x46, 0x4c, 0x30, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x30, 0x7c, 0x7e, 0x33, 0x11, 0x2d, 0x21, 0x62, 0x74, 0x38, 0x18, 0x00, 0x00,
  // Frame 4:
  0x00, 0x00, 0x00, 0x6, 0xf, 0x3f, 0xa3, 0xcd, 0x81, 0xcd, 0x23, 0x27, 0x18, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x1c, 0x3e, 0x1f, 0x19, 0x8, 0x16, 0x10, 0x11, 0x3a, 0x1c, 0xe, 0x00, 0x00,
  // Frame 5:
  0x00, 0x00, 0x00, 0x4, 0xf, 0x3f, 0xa3, 0xcd, 0x81, 0xcd, 0x23, 0x27, 0x18, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x18, 0x3e, 0x3f, 0x19, 0x8, 0x16, 0x10, 0x31, 0x3a, 0x1c, 0xc, 0x00, 0x00,};
const unsigned char playerRunLeft[] PROGMEM = {
  // Width & Height:
  16, 16,
  // Frame 0:
  0x00, 0x00, 0x00, 0x60, 0x94, 0x8e, 0x36, 0x6, 0x34, 0x8e, 0xfe, 0x34, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0xb8, 0xc4, 0x83, 0xda, 0xa3, 0xe6, 0x1e, 0x2, 0x00, 0x00, 0x00, 0x00,
  // Frame 1:
  0x00, 0x00, 0x00, 0xc0, 0x24, 0x1c, 0x6c, 0xc, 0x68, 0x1e, 0xf8, 0x68, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x80, 0xf1, 0x89, 0x86, 0xb4, 0xc6, 0xcd, 0xbf, 0x2, 0x00, 0x00, 0x00, 0x00,
  // Frame 2:
  0x00, 0x00, 0x00, 0x60, 0x9c, 0x8c, 0x36, 0x6, 0x36, 0x8c, 0xfc, 0x3a, 0x10, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x70, 0xe8, 0xc4, 0x43, 0x5a, 0x23, 0x66, 0xfc, 0xf0, 0x00, 0x00, 0x00, 0x00,
  // Frame 3:
  0x00, 0x00, 0x00, 0x30, 0x4c, 0x46, 0x9b, 0x3, 0x9b, 0x46, 0x7e, 0x1e, 0xa, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x18, 0x38, 0x74, 0x62, 0x21, 0x2d, 0x11, 0x33, 0x7e, 0x7c, 0x30, 0x00, 0x00, 0x00,
  // Frame 4:
  0x00, 0x00, 0x00, 0x18, 0x27, 0x23, 0xcd, 0x81, 0xcd, 0xa3, 0x3f, 0xf, 0x6, 0x00, 0x00, 0x00,
  0x00, 0x00, 0xe, 0x1c, 0x3a, 0x11, 0x10, 0x16, 0x8, 0x19, 0x1f, 0x3e, 0x1c, 0x00, 0x00, 0x00,
  // Frame 5:
  0x00, 0x00, 0x00, 0x18, 0x27, 0x23, 0xcd, 0x81, 0xcd, 0xa3, 0x3f, 0xf, 0x4, 0x00, 0x00, 0x00,
  0x00, 0x00, 0xc, 0x1c, 0x3a, 0x31, 0x10, 0x16, 0x8, 0x19, 0x3f, 0x3e, 0x18, 0x00, 0x00, 0x00,};
const unsigned char playerIdleRight[] PROGMEM = {
  // Width & Height:
  16, 16,
  // Frame 0:
  // Frame 1:
  0x00, 0x00, 0x00, 0x00, 0x1a, 0x3c, 0xcc, 0xe7, 0x96, 0x87, 0xc4, 0xf8, 0x00, 0x00, 0x00, 0x00,
  // Frame 2:
  0x00, 0x00, 0x00, 0x00, 0x34, 0x4f, 0xcd, 0xe6, 0x84, 0x86, 0xc9, 0xf1, 0x30, 0x00, 0x00, 0x00,
  // Frame 3:
  0x00, 0x00, 0x00, 0x00, 0x68, 0xfc, 0x1c, 0x68, 0xc, 0x6c, 0x1c, 0x28, 0xc0, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x8, 0x3f, 0xe7, 0xb2, 0xca, 0x82, 0xc5, 0xb9, 0x20, 0x00, 0x00, 0x00,};
const unsigned char playerIdleLeft[] PROGMEM = {
  // Width & Height:
  16, 16,
  // Frame 0:
  // Frame 1:
  0x00, 0x00, 0x00, 0x00, 0xf8, 0xc4, 0x87, 0x96, 0xe7, 0xcc, 0x3c, 0x1a, 0x00, 0x00, 0x00, 0x00,
  // Frame 2:
  0x00, 0x00, 0x00, 0x30, 0xf1, 0xc9, 0x86, 0x84, 0xe6, 0xcd, 0x4f, 0x34, 0x00, 0x00, 0x00, 0x00,
  // Frame 3:
  0x00, 0x00, 0x00, 0xc0, 0x28, 0x1c, 0x6c, 0xc, 0x68, 0x1c, 0xfc, 0x68, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x20, 0xb9, 0xc5, 0x82, 0xca, 0xb2, 0xe7, 0x3f, 0x8, 0x00, 0x00, 0x00, 0x00,};
const unsigned char playerFallRight[] PROGMEM = {
  // Width & Height:
  16, 16,
  // Frame 0:
  // Frame 1:
  0x00, 0x00, 0x00, 0x00, 0x1e, 0x7f, 0x46, 0x9b, 0x3, 0x9b, 0x47, 0x4d, 0x30, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x30, 0x7c, 0x7e, 0x33, 0x11, 0x2d, 0x21, 0x62, 0x74, 0x38, 0x18, 0x00, 0x00,};
const unsigned char playerFallLeft[] PROGMEM = {
  // Width & Height:
  16, 16,
  // Frame 0:
  // Frame 1:
  0x00, 0x00, 0x00, 0x30, 0x4d, 0x47, 0x9b, 0x3, 0x9b, 0x46, 0x7f, 0x1e, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x18, 0x38, 0x74, 0x62, 0x21, 0x2d, 0x11, 0x33, 0x7e, 0x7c, 0x30, 0x00, 0x00, 0x00,};
// Floor
const unsigned char floorTile[] = {
  // Width & Height:
  8, 8,
  // Frame 0:
const unsigned char nullTile[] = {
  // Width & Height:
  8, 8,
  // Frame 0:
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,};
andylatham82
PART 2:
Constants.h:
Code: [Select]
#pragma once
const char tileArraySize = 31;
LevelMap.cpp:
Code: [Select]
#include "Tile.cpp"
class LevelMap {
  public:
    Tile tiles[2] = {Tile(nullTile),Tile(floorTile)};
      { // Level 0:
      { // Level 1:
    LevelMap(int a) {
    Draw() {
Player.cpp:
Code: [Select]
//#include "Solid.cpp"
#include "Tile.cpp"
class Player {
  public:
    Sprite sprite;
    int screenPosX = 64;  // -32768 to 32767 (screen 128 pixels wide).
    int screenPosY = 0;  // -128 to 127 (screen only 64 pixels high).
    int posX = screenPosX * 256;  // 16-bit value.
    int posY = screenPosY * 256;
    int state = 0;      // 0 = idleRight
                        // 1 = idleLeft
                        // 2 = runRight
                        // 3 = runLeft
                        // 4 = fallRight
                        // 5 = fallLeft
    int velocityX = 0;
    int velocityY = 0;
    char velocityStep = 16;
    char gravity = 32;
    int velocityXMax = 256;
    int velocityYMax = 256;
    char directionX = 1;
  void Update() {
    char stateOld = state;
    if (velocityY == 0) {
      sprite.frameRate = 60;
      sprite.animationLength = 6;
      if (velocityX > 0)
        state = 2;
      else if (velocityX < 0)
        state = 3;
      else {
        sprite.frameRate = 15;
        sprite.animationLength = 4;
        if (directionX > 0)
          state = 0;
        if (directionX < 0)
          state = 1;
    else {
      sprite.frameRate = 45;
      sprite.animationLength = 2;
      if (directionX > 0)
        state = 4;
      if (directionX < 0)
        state = 5;
    sprite.Update(stateOld == state);
    if (velocityY < (4 * 256))
      velocityY += gravity;
    if (velocityX >= 12)
      velocityX -= 12;
    else if (velocityX <= -12)
      velocityX += 12;
      velocityX = 0;
    int tempX = posX + velocityX;
    int tempY = posY + velocityY;
    for (int i = 0; i < tileArraySize; i++) {
      // Bottom collision.
      if ((tempY >> 8) + sprite.height >= (tiles[i].posY >> 8)
          and (tempY >> 8) < (tiles[i].posY >> 8) + 8
          and (tempX >> 8) + 11 > tiles[i].posX >> 8
          and (tempX >> 8) + 5 < (tiles[i].posX >> 8) + 8) {
        posY += (tiles[i].posY - (sprite.height * 256)) - posY;
        velocityY = 0;
      else {
      // Right collision.
      if ((tempX >> 8) + 11 >= (tiles[i].posX >> 8)
          and (tempY >> 8) + sprite.height > tiles[i].posY >> 8
          and directionX > 0) {
        posX += tiles[i].posX - (posX + (11 * 256));
        velocityX = 0;
      // Left collision.
      if ((tempX >> 8) + 5 <= (tiles[i].posX >> 8) + 8
          and (tempX >> 8) + 5 > tiles[i].posX
          and directionX < 0) {
        posX -= (posX + (5 * 256)) - (tiles[i].posX + (8 * 256));
        velocityX = 0;
    posX += velocityX;
    posY += velocityY;
    if (posY > (66 * 256))
      Reset();
  void Draw() {
    switch (state) {
      case 0: // Idle Right
        sprite.Draw(posX, posY, playerIdleRight);
      case 1: // Idle Left
        sprite.Draw(posX, posY, playerIdleLeft);
      case 2: // Run Right
        sprite.Draw(posX, posY, playerRunRight);
      case 3: // Run Left
        sprite.Draw(posX, posY, playerRunLeft);
      case 4: // Fall Right
        sprite.Draw(posX, posY, playerFallRight);
      case 5: // Fall Left
        sprite.Draw(posX, posY, playerFallLeft);
  void Reset() {
    posX = 16384;
    posY = 0;
    velocityX = 0;
    velocityY = 0;
    directionX = 1;
// Fixed Point 8.8
// 8 bits in a byte.
// In 8 bits (1 byte) you can store 0 - 255 (enough for a coordinate
// on the small screen.
// In 16 bits (2 bytes) you can store 0 - 65536. Use 1st byte for integer
// and 2nd byte for fraction.
// Increment the bottom 8 bits until it wraps around 256, and the upper
// 8 bits will increment by 1.
// Acts like a decimal: 0.0 to 255.255
// Use whole 16 bits to calculate velocities but only use the upper 8
// bits to render the object to the screen, discarding the lower 8 with
// the >> operator.
// 256 is 1 pixel per frame. 128 is 0.5 pixels per frame.
Sprite.cpp:
Code: [Select]
#pragma once
class Sprite {
  public:
    Sprites sprites;
    bool active = true;
    Sprite() {
      if (active) {
        if (!sameState)
          currentFrame = 0;
Tile.cpp:
Code: [Select]
#pragma once
class Tile {
  public:
    Sprite sprite;
      memcpy(tileTexture, texture, sizeof(texture));
    void Update() {
andylatham82
I just realised I can attach my code in a zip file. D'oh!
arduarn
#11
Nov 20, 2017, 03:55 pm Last Edit: Nov 20, 2017, 04:22 pm by arduarn
Code: [Select]
You seem to have changed this from your original post. I think the original post was correct in using the member variable tileTexture for the sizeof. When an array is passed as a parameter to a function, the size information is lost and a sizeof will just return the size of a pointer.
"Is this definitely the problem? I ask because if I remove the PROGMEM command entirely, I still can't get the correct result."
Oops, definitely was too strong a word...the Arduboy2 library that you are using seems to be expecting the bitmaps to be in flash and uses the appropriate helper functions.
Code: [Select]
The tile bitmaps are constant and are stored in flash (they have to be by the looks of things), so I think you are wrong to try to copy them into RAM (you would have to use a pgm_* function to do so anyway).
Make the bitmaps PROGMEM again. Remove the memcpy() and just store a pointer to the const bitmap data in the Tile.
See if that makes any difference.
andylatham82
#12
Nov 20, 2017, 04:57 pm Last Edit: Nov 20, 2017, 05:02 pm by andylatham82
Ok so I've implemented pointers now, avoiding copying the array.
LevelMap.cpp:
Code: [Select]
#include "Tile.cpp"
class LevelMap {
  public:
    const unsigned char *pTileTexture = floorTile;
    Tile tiles[2] = {Tile(pTileTexture),Tile(pTileTexture)};
      { // Level 0:
      { // Level 1:
    LevelMap(int a) {
    Draw() {
Tile.cpp:
Code: [Select]
#pragma once
class Tile {
  public:
    Sprite sprite;
    unsigned char *pTileTexture;
    Tile(const unsigned char pTexture) {
      pTileTexture = pTexture;
    void Update() {
      sprite.Draw(posX, posY, *pTileTexture);
The result is something very close to how the level should look, but is mangling the graphics. I'm not 100% sure if I'm using the pointers right, I haven't used them much before. I've attached an image of the screen.
arduarn
The pointer dereference is IMO incorrect... I'm a little confused as to why it would compile...
The original LevelMap.cpp was OK, no need to worry about pointers there; floorTile and nullTile will automatically collapse to a pointer when required.
Try this:
Code: [Select]
    const unsigned char *pTileTexture;
    Tile(const unsigned char *pTexture) :  pTileTexture(pTexture) {
      sprite.Draw(posX, posY, pTileTexture);
andylatham82
Try this:
Code: [Select]
This worked! Thank you! I didn't understand the modification to the Tile constructor at first, as I thought the colon was used to pass parameters to an inherited class, but I now understand that this is the only way to modify the value of a const variable. Is that right? Is it necessary for the unsigned char to be const though? I tested without it being const and putting pTileTexture = pTexture in the body of the constructor and it still works. Is it just a case of being best practice to keep types consistent?
The other thing I'm slightly unsure of is the dereferencing. Why do I not need the dereferencing operator (*) when calling the sprite.Draw function? Is it because the pTileTexture pointer is pointing at an array?
Thanks so much for helping me with this.
