The "
official" UNO kit is probably your best bet as a beginner.
If you need to play with WiFi then the
MKR1000 starter kit would be a great choice.
Both will provide you with a "From the ground up" approach from basic electronics to a good grounding in basic programming and give you the confidence you need to go further.
They have a book that steps you through each topic in an easy to follow way.
There are of course the NON official kits but your support for those in here would be more limited as they are not using the official book to follow a known path.
