Topic: Max upload to DUE? (Read 981 times) previous topic - next topic
KG_DK
I have a DUE, whitch until now worked well, but now I can't upload the SW to the board.
When trying to upload, it say:
Send auto-baud
No device found on COM10
Set binary mode
An error occurred while uploading the sketch
But when I use Board Info, it say:
BN: Arduino Due (Programming Port)
VID: 2341
PID: 003D
SN: 5533031373535180C011
I have two other DUE, one is OK, but the last also fault, it is on COM6.
Is there a max uploads?
ard_newbie
There is no maximum number of uploads, except that you can only write the Flash maybe 10000 times (or more).
Have you tried to push the erase button for 3 seconds, then the reset button for 3 seconds then choose the correct COM port ( COM X (DUE Programming Port)) if you are using the programming Port., then upload your sketch.
Do not plug any external peripheral  to your board when uploading.
KG_DK
Yes, I have tryed to erase and reset a lot og times.
The errors started some time ago, and then I user erase to get it to work, but it do not work any more.
I have uploadet maybe 500 times but not 10.000.
KG_DK
I don't use all the program memory.
Is it possible to tell the uploader to use another area to store the program?
pert
@KG_DK created a new thread for discussion of that topic:
http://forum.arduino.cc/index.php?topic=512981
