Topic: how to send data from GPRS Module to php Script !? (Read 5606 times) previous topic - next topic
ahmed_sayed
Hello ...
I am a beginner in arduino Develop .. this my first project
i need to send some data from adruino sensor to my server (php script) throw GPRS
i'm using SIM808 GSM GPRS GPS
i try many codes but The moisture values are shown on the serial monitor but still not in the php script. in all of these codes
any one can help me !!
this my code for arduino
Code: [Select]
#include <SoftwareSerial.h>
#include <Wire.h>
SoftwareSerial mySerial(2, 3);            // RX, TX Pins
String apn = "Vodafone";                       //APN
String apn_u = "Internet";                     //APN-Username
String apn_p = "Internet";                     //APN-Password
String url = "http://abozezo959.000webhostapp.com/index1.php";  //URL for HTTP-POST-REQUEST
String data1;   //String for the first Paramter (e.g. Sensor1)
String data2;   //String for the second Paramter (e.g. Sensor2)
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  delay(10000);
void loop() { // run over and over
    data1 = "123";
    data2 = "ABC";
    gsm_sendhttp(); //Start the GSM-Modul and start the transmisson
    delay(60000); //Wait one minute
void gsm_sendhttp() {
  mySerial.println("AT");
  runsl();//Print GSM Status an the Serial Output;
  delay(4000);
  mySerial.println("AT+SAPBR=3,1,Contype,GPRS");
  runsl();
  delay(100);
  mySerial.println("AT+SAPBR=3,1,APN," + apn);
  runsl();
  delay(100);
  mySerial.println("AT+SAPBR=3,1,USER," + apn_u); //Comment out, if you need username
  runsl();
  delay(100);
  mySerial.println("AT+SAPBR=3,1,PWD," + apn_p); //Comment out, if you need password
  runsl();
  delay(100);
  mySerial.println("AT+SAPBR =1,1");
  runsl();
  delay(100);
  mySerial.println("AT+SAPBR=2,1");
  runsl();
  delay(2000);
  mySerial.println("AT+HTTPINIT");
  runsl();
  delay(100);
  mySerial.println("AT+HTTPPARA=CID,1");
  runsl();
  delay(100);
  mySerial.println("AT+HTTPPARA=URL," + url);
  runsl();
  delay(100);
  mySerial.println("AT+HTTPPARA=CONTENT,application/x-www-form-urlencoded");
  runsl();
  delay(100);
  mySerial.println("AT+HTTPDATA=192,10000");
  runsl();
  delay(100);
  mySerial.println("params=" + data1 + "~" + data2);
  runsl();
  delay(10000);
  mySerial.println("AT+HTTPACTION=1");
  runsl();
  delay(5000);
  mySerial.println("AT+HTTPREAD");
  runsl();
  delay(100);
  mySerial.println("AT+HTTPTERM");
  runsl();
//Print GSM Status
void runsl() {
  while (mySerial.available()) {
    Serial.write(mySerial.read());
and this my code for php
Code: [Select]
<?php
$timestamp
date("d-m-Y - H:i:s");
$datastring $_POST["params"];
$myfile fopen("newfile.txt""w") or die("Unable to open file!");
$txt $timestamp " - ".$datastring."\n";
fwrite($myfile$txt);
fclose($myfile);
echo
$txt;
dannable
What output are you seeing on the screen?
My first thought is that the function runsl() may be returning prematurely. You send a command, then immediately record the response. It can take several seconds for the response to arrive, by which time you will have sent several more commands. A more elegant way would be to wait until you get a response, then keep reading until you are sure there are no more characters to come.
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
ahmed_sayed
this is the output Monitor ...
SawunyamaB
did you finally get the thing to work.
if so can you assist me because iam trying a similar project except i want to send rfid to php script to update my database
regards
