Topic: Problema con la library RF24 per comunicazione Wi-fi (Read 364 times) previous topic - next topic
3drone
Buongiorno, ho provato a scaricare su un Arduino Nano il codice per poter trasmettere informazioni via Wi-fi con il NRF24L01. Ho copiato il codice da un video tutorial su youtube solo che mi dà questo messaggio quando clicco upload:
Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 3344 bytes (10%) of program storage space. Maximum is 30720 bytes.
Global variables use 217 bytes (10%) of dynamic memory, leaving 1831 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x61
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x61
Il codice è questo:
Code: [Select]
#include <SPI.h>                      //the communication interface with the modem
#include "RF24.h"                     //the library which helps us to control the radio modem
//define the input pins
int x_axis = A0;
int y_axis = A1;
int potPin = A2;
//define variable values
int xValue;
int yValue;
int potValue;
int data[1];
RF24 radio(5,10);                     //5 and 10 are a digital pin numbers to which signals CE and CSN are connected.
const uint64_t pipe = 0xE8E8F0F0E1LL; //the address of the modem, that will receive data from Arduino.
void setup(void){
 radio.begin();                      //it activates the modem.
 radio.openWritingPipe(pipe);        //sets the address of the receiver to which the program will send data.
void loop(){
 //Send X-axis data
 xValue = analogRead(x_axis);
 xValue = map(xValue, 0, 1023, 0, 10);
 data[0] = xValue;
 radio.write(data, 1);
 //Send Y-axis data
 yValue = analogRead(y_axis);
 yValue = map(yValue, 0, 1023, 11, 20);
 data[0] = yValue;
 //Send Potentiometer data
 potValue = analogRead(potPin);
 potValue = map(potValue, 0, 1023, 21, 30);
 data[0] = potValue;
La  library sta nella stessa cartella del codice.
Qualcuno mi può aiutare a capire qual'è il problema?
Grazie
gpb01
>3drone:  ti ricordo che in conformità al regolamento, punto 7, devi editare il tuo post (quindi NON scrivendo un nuovo post, ma utilizzando il bottone More -> Modify che si trova in basso a destra del tuo post) e racchiudere il codice all'interno dei tag CODE (... sono quelli che in edit inserisce il bottone con icona fatta così: </>, tutto a sinistra).
Grazie,
Guglielmo
Search is Your friend ... or I am Your enemy !
