Topic: Open source Animatronic Animator Software  (Read 779 times) previous topic - next topic
Napalm1432
Nov 29, 2017, 01:27 pm Last Edit: Nov 29, 2017, 01:40 pm by Napalm1432
Hi there,
So i'm working on a project now, where i want to animate a animatronic parrot. Now using just code wasn't visual enough for me. so i needed something better, i had been looking around for utilities that let me animate servo's easily, but it never worked the way i needed it. Besides that, no open source options where available (not that i could find at least).
So, I decided to make my own open source software for it!
I already made quite the start. being able to easily set servo values, set framerates, animation lengths etc. saving it to a file. Which can then be read on on arduino and play the animation back in the right speed.
Now i made quite a good start, and functions for what i need so far. But ofcourse it can be better, way better.
That's where i need your help, sadly i'm not that much of a programming expert to do everything i want yet.
I have put this project up on github, so that anyone can work on it, or simply use the current version.
A readme is included there with much more information about what the software can, and can't do.
Thank you if you read all the way trough :), and thanks even more, if you're helping!
Github page:
https://www.github.com/Napalm1432/ServoAnimator
Lynk101
Wow thank you so much this is just what I need!
djsfantasi
#2
Mar 27, 2019, 12:38 am Last Edit: Mar 27, 2019, 12:38 am by djsfantasi
Take a look on Instructables for djsfantasi. I have an 'ible which describes my software. Ive developed a program which implements an interpreted language that I call a-code (for animatronic code). I believe listings are available there as well.
Perhaps this can help you?
