Topic: WS2812B Wrong colors (Read 11495 times) previous topic - next topic
Pete-Repeat
Any thoughts why it's only a problem at lower brightness or off? Could it be a data line issue?? Or perhaps the strip is damaged? Although seeing it works perfectly fine at the higher brightness makes me think power and the leds plus drivers are ok? This is a question not a statement as obviously I'm not too sure.
Maybe I try a different value resistor or maybe try a different digital out or perhaps borrow the esp8266 from the strip working properly? Problem is I may need to pull the strip's down and unsolder plus resolder so I'm a little hesitant unless there is reason for the problems to only be at the lower brightness or off for me to do that.
