Topic: Potentiometer with Continuous Rotation (Read 34044 times) previous topic - next topic
beardedkid
Alright,
I am working on a really fun project. I'm putting a potentiometer inside of a See 'n Say and using the readings to change the audio output. But the arrow on the device only spins in one direction, so in order to do this I need to find a pot with a full, continuous 360 degree range of motion.
Does anyone know where the best place to find one is?
mowcius
So do you mean 360deg or continuous or multi-turn?
You can get multi turn potentiometers which will do say 4 turns or so or if you want continuous, you are looking for a rotary encoder.
Mowcius
Grumpy_Mike
You can get continuous rotation pots, these are designed for use in servos and are quite pricey.
A typical example is:-
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=2943690
beardedkid
Thanks,
I'll check out the rotary encoder and try modifying one of my pots.
Appreciate the input.
CrossRoads
There are these at digikey, 74 cents, 360 rotation. Supply your own shaft.
CrossRoads
Guess the link would have been good:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=P12426TR-ND
Search for potentiometer, filter on continuous
afclewis
If you are looking for a "cheap" small shaft encoder have a look at http://www.usdigital.com/products/ma3/ if you're in europe and your german is passable (or use chrome and translate feature) you can order online from the german site, or just give them a call in the USA or send a fax ( i know, who thought people still use fax'es).
Hope this helps
CrossRoads
#7
Feb 09, 2011, 10:14 am Last Edit: Feb 09, 2011, 10:21 am by CrossRoads Reason: 1
$40! Hardly seems 'cheap'!
I think I'd give the 74 cents approach a shot first :)
Ok, I tried to order to confirm price,
need a slightly different part number, $2.06 each.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=P12426CT-ND
Only has 330 degree of resistance coverage, put two back to back arranged so that their  0 +/- 14 locations didn't overlap.
Minkowski
Really low-budget scrounge. Got an old-style mechanical mouse in the junk box? Two rotary encoders and a couple switches for free. If you're lucky the parts can be removed from the housing for re-use. Might have to remove crud.
afclewis
Quote
Notice "cheap" with quotation's either side!!! It was supposed to imply that it is relatively cheap!! Not cheap full stop.......
westfw
If you can live with a mechanical rotary encoder:
http://www.bgmicro.com/pushbuttonmechanicalrotaryencoder.aspx
http://www.allelectronics.com/make-a-store/item/REC-3/ROTARY-ENCODER/1.html
http://www.goldmine-elec-products.com/prodinfo.asp?number=G16267
http://www.sureelectronics.net/goods.php?id=221
Or even modern mice usually have an encoder for the "wheel" portion.
Also, there are ways to use a stepper motor as an encoder...
zaphil
Farnell group are pretty world-wide these days
This is just under 6ukp and is 15ppr (30 if you matrix the A&B channels).
http://uk.farnell.com/alps/ec11j1520801/encoder-rotary-30ppr/dp/1656445
