Jetzt habe ich deinen Hinweis geschnalllt::
// Model railway switch (untested) by 'jurs'
// use button with INPUT and external pull-down resistor
// or with INPUT_PULLUP and internal pull-up resistor
#define BUTTONPIN 2
#define INPUTMODE INPUT // INPUT or INPUT_PULLUP
#define LEDPIN 3
#define POTILEFT 4
#define POTIRIGHT 5
#define SERVOPIN 6
#define SERVOMIDDLE 1500 // 1500µs impulse duration means servo middle position
// define some symbolic constants
enum {LEFT, RIGHT}; // directions
enum {OFF, RED, GREEN}; // LED states
int currentOrientation;
void switchLED(int ledState)
switch(ledState)
case RED:
pinMode(LEDPIN,OUTPUT);
digitalWrite(LEDPIN,HIGH);
case GREEN:
digitalWrite(LEDPIN,LOW);
default:
pinMode(LEDPIN,INPUT);
void switchServo(int orientation)
switchLED(OFF);
unsigned long time=millis();
while (millis()-time<500) updateServo(orientation); // half second delay updating the servo
if (orientation==LEFT) switchLED(RED);
else switchLED(GREEN);
currentOrientation=orientation;
void updateServo(int orientation)
int servoImpulse=SERVOMIDDLE;
if (orientation==LEFT) servoImpulse-= analogRead(POTILEFT)/3;
else servoImpulse+= analogRead(POTIRIGHT)/3;
digitalWrite(SERVOPIN,HIGH);
delayMicroseconds(servoImpulse);
digitalWrite(SERVOPIN,LOW);
delayMicroseconds(20000-servoImpulse);
boolean buttonPressed()
boolean result=false;
static byte lastButtonState;
byte buttonState = digitalRead(BUTTONPIN);
if (INPUTMODE==INPUT_PULLUP) buttonState=!buttonState;
if (buttonState == HIGH && lastButtonState == LOW) result=true;
lastButtonState=buttonState;
return result;
pinMode(BUTTONPIN, INPUTMODE);
pinMode(LEDPIN, OUTPUT);
pinMode(SERVOPIN, OUTPUT);
switchServo(LEFT);
if (buttonPressed())
if (currentOrientation==LEFT) switchServo(RIGHT);
else switchServo(LEFT);
updateServo(currentOrientation);
