Topic: IEEE754 Tools broke (Read 1 time) previous topic - next topic
aweatherguy
See the link below. I've been using this code with success now for some time. I just re-compiled a sketch under the 1.8.4 IDE and this code no longer works -- it generates NaN when trying to convert valid doubles to floats.
Has anyone else seen this? I wonder if the compiler changed the way bitfields are packed within structures.
http://forum.arduino.cc/index.php?topic=186860.0
aweatherguy
Well, I gave up trying to fix that stuff. The only thing I needed was to convert a byte-array containing a double (big endian) to float.
I wrote the following function to do this and it seems to work, accurate down to the last bit. There are some limitations (see code) but they are don't cares for my usage.
I think it's pretty efficient, too.
Code: [Select]
Copyright © 2017, aweatherguy
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
The name "aweatherguy" may not be used to endorse or promote products
derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL <COPYRIGHT HOLDER> BE LIABLE FOR ANY
DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#define USE_ROUNDING    1
#define BUF_IS_BIG_ENDIAN   1
#include <inttypes.h>
__attribute__((noinline))
float PackedDouble2Float(uint8_t* buf)
    // Efficient conversion from 8-byte double to floating point.
    // Basic overview of steps:
    // 1) Move 5 MSBs of double into registers r21..r25
    // 2) Test bit 4 in LSB for optional rounding. If set, add 0x10 to LSB,
    //    and propagate carry through remaining 4 bytes. Because there is no
    //    ADDI/ADCI instructions, we must use SUBI/SBCI instead.
    // 3) Shift 5-byte word left 3 bits.
    // 4) Flip bit 6 of MSB (takes care of exponent adjustment)
    // 5) Turn off bit 7 of MSB (sign bit)
    // 6) If sign bit of source was set, then set bit 7 of MSB
    // Finished. Result is in r22..r25 which is the proper location for
    // return to the calling function (see avr-gcc compiler calling conventions).
    // Limitations (these will result in unpredictable results):
    // - No support for special values such as Zero, Inf or NaN
    // - No detection of exponent overflow
    // Testing
    // So far, basic conversion of numbers and proper behavior of rounding have been
    // tested. Rounding which results in overflow of mantissa requiring exponent
    // adjustment also seems to work. No testing of special values or numbers
    // close to limts has been done.
    // Calling conventions:
    // The address of buf is passed in r24/r25, and the compiler will emit
    // a "movw r30,r24" to get that into the Z register before inserting the assembly code.
    // The result must be returned in r22..r25. If the __asm__ code simply leaves the result there,
    // nothing else needs to be done; the compiler will emit a "ret" instruction without
    // altering the values left in those registers.
    __asm__ __volatile__ (
#if BUF_IS_BIG_ENDIAN
 "ld  r25,z \n\t"
 "ldd r24,z+1 \n\t"
 "ldd r23,z+2 \n\t"
 "ldd r22,z+3 \n\t"
 "ldd r21,z+4 \n\t"
#else
 "ld  r21,z \n\t"
 "ldd r22,z+1 \n\t"
 "ldd r23,z+2 \n\t"
 "ldd r24,z+3 \n\t"
 "ldd r25,z+4 \n\t"
#endif
#if USE_ROUNDING
 "ldi r20,0x10   \n\t"
 "and r20,r21    \n\t"
 "breq .+10 \n\t"
 "subi r21,0xef  \n\t"
 "sbci r22,0xff  \n\t"
 "sbci r23,0xff  \n\t"
 "sbci r24,0xff  \n\t"
 "sbci r25,0xff  \n\t"
#endif
 "ldi r20,3 \n\t"
 "lsl r21 \n\t"
 "rol r22 \n\t"
 "rol r23 \n\t"
 "rol r24 \n\t"
 "rol r25 \n\t"
 "dec r20 \n\t"
 "brne .-14 \n\t"
 "ldi r20,0x40 \n\t"
 "eor r25,r20 \n\t"
 "andi r25,0x7f \n\t"
 "ld  r20,z \n\t"
 "lsl r20 \n\t"
 "brcc .+2 \n\t"
 "ori r25,0x80   \n\t"
 : "z" (buf)
 : "r20", "r21", "r22", "r23", "r24", "r25"
robtillaart
#2
Dec 09, 2017, 09:58 pm Last Edit: Dec 09, 2017, 10:34 pm by robtillaart
@aweatherguy
Thanks for sharing the problem and the solution!
Can you give a (minimal) sketch with a double (byte[8]) that generates the NaN under 1.8.4
and that worked in previous versions? I like to understand what happened.
Did you use another board by accident?
TIA,
Rob
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
robtillaart
I have downloaded 1.8.5 and see small differences in the output of a simple sketch.
The reason for the differences I see are the filler used in _DBL. This is not set to anything so it takes over whatever the value the stack/heap has at that moment. However the working of the code in my test sketch is identical so far. Still I think there need to be a fix to zero that filler.
Code: ("first fix") [Select]
void float2DoublePacked(float number, byte* bar, int byteOrder=LSBFIRST)
    _FLOATCONV fl;
    fl.f = number;
    _DBLCONV dbl;
    dbl.p.filler = 0;
    dbl.p.s = fl.p.s;
    dbl.p.e = fl.p.e-127 +1023;  // exponent adjust
    dbl.p.m = fl.p.m;
#ifdef IEEE754_ENABLE_MSB
    if (byteOrder == LSBFIRST)
#endif
        for (int i=0; i<8; i++)
            bar[i] = dbl.b[i];
            bar[i] = dbl.b[7-i];
#endif
to be continued
Rob Tillaart
robtillaart
#4
Dec 10, 2017, 12:44 am Last Edit: Dec 10, 2017, 01:29 am by robtillaart
 I will install and test with the 1.8.4 version of the IDE
I use windows, which platform do you use?
Still I need an example from you that is failing for 1.8.4 and not in an earlier version
After zeroing the filler with this line    dbl.p.filler = 0;
I tried 1.8.1  1.8.4 and 1.8.5 and they gave me all the same output
Although a working testsketch is no guarantee of absense of bugs I cannot reproduce a failure yet.
When this problem is understood I will update code and testsketch on github.
Code: (testsketch) [Select]
//    FILE: float2double.ino
//  AUTHOR: Rob Tillaart
// VERSION: 0.1.00
// PURPOSE: experimental expands a float in a IEEE 754 double to be printed to PC.
// http://en.wikipedia.org/wiki/Double_precision
// http://en.wikipedia.org/wiki/Single-precision_floating-point_format
// Released to the public domain
#include <IEEE754tools.h>
byte x[8];
  for (float f = -50.0; f < 50.0; f += 10.0)
    dumpFloat(f);
    float2DoublePacked(f, x, LSBFIRST);
    dumpByteArray(x);
    float g = doublePacked2Float(x, LSBFIRST);
    Serial.println(g, 20);
  dumpFloat(0.15625);  // to check wikipedia
  Serial.println("PI-check");
  Serial.println(PI, 20);
  float2DoublePacked(PI, x);
  dumpByteArray(x);
  float f = doublePacked2Float(x, LSBFIRST);
  Serial.println(f, 20);
  Serial.println("done");
void dumpByteArray(byte *ar)
  for (int i = 0; i < 8; i++)
    Serial.print(ar[i], HEX);
    Serial.print('\t');
Rob Tillaart
