Hi.
Im using an Leonardo with max 31865 + pt100 and get a value(temp) that is in room temp about +70 degrees to high.
Tried with 2 different types of library but whit same result. Tested with a different sensor and a different max31865 but with same result.
What have i done wrong?
Jonas
* MAX31865 Basic Example
* Copyright (C) 2015 Ole Wolf <wolf@blazingangles.com>
* Example code that reads the temperature from an MAX31865 and outputs
* it on the serial line.
* Wire the circuit as follows, assuming that level converters have been
* added for the 3.3V signals:
* Arduino Uno --> MAX31865
* CS: pin 10 --> CS
* MOSI: pin 11 --> SDI (must not be changed for hardware SPI)
* MISO: pin 12 --> SDO (must not be changed for hardware SPI)
* SCK: pin 13 --> SCLK (must not be changed for hardware SPI)
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <SPI.h>
#include <MAX31865.h>
#define RTD_CS_PIN 10
MAX31865_RTD rtd( MAX31865_RTD::RTD_PT100, RTD_CS_PIN );
Serial.begin( 115200 );
/* Initialize SPI communication. */
SPI.begin( );
SPI.setClockDivider( SPI_CLOCK_DIV16 );
SPI.setDataMode( SPI_MODE3 );
/* Allow the MAX31865 to warm up. */
delay( 100 );
/* Configure:
V_BIAS enabled
Auto-conversion
1-shot disabled
3-wire enabled
Fault detection: automatic delay
Fault status: auto-clear
50 Hz filter
Low threshold: 0x0000
High threshold: 0x7fff
rtd.configure( true, true, false, true, MAX31865_FAULT_DETECTION_NONE,
true, true, 0x0000, 0x7fff );
rtd.read_all( );
if( rtd.status( ) == 0 )
double temperature = rtd.temperature( );
Serial.print( " T = ");
Serial.print( temperature, 1 );
Serial.println(" deg C" );
Serial.print( "RTD fault register: " );
Serial.print( rtd.status( ) );
Serial.print( ": " );
if( rtd.status( ) & MAX31865_FAULT_HIGH_THRESHOLD )
Serial.println( "RTD high threshold exceeded" );
else if( rtd.status( ) & MAX31865_FAULT_LOW_THRESHOLD )
Serial.println( "RTD low threshold exceeded" );
else if( rtd.status( ) & MAX31865_FAULT_REFIN )
Serial.println( "REFIN- > 0.85 x V_BIAS" );
else if( rtd.status( ) & MAX31865_FAULT_REFIN_FORCE )
Serial.println( "REFIN- < 0.85 x V_BIAS, FORCE- open" );
else if( rtd.status( ) & MAX31865_FAULT_RTDIN_FORCE )
Serial.println( "RTDIN- < 0.85 x V_BIAS, FORCE- open" );
else if( rtd.status( ) & MAX31865_FAULT_VOLTAGE )
Serial.println( "Overvoltage/undervoltage fault");
Serial.println( "Unknown fault; check connection" );
delay( 3000 );
