Topic: max 31865 and pt100 showing wrong temp (Read 751 times) previous topic - next topic
jsandbacka
Hi.
Im using an Leonardo with max 31865 + pt100 and get a value(temp) that is in room temp about +70 degrees to high.
Tried with 2 different types of library but whit same result. Tested with a different sensor and a different max31865 but with same result.
What have i done wrong?
Jonas
 * MAX31865 Basic Example
 * Copyright (C) 2015 Ole Wolf <wolf@blazingangles.com>
 * Example code that reads the temperature from an MAX31865 and outputs
 * it on the serial line.
 * Wire the circuit as follows, assuming that level converters have been
 * added for the 3.3V signals:
 *    Arduino Uno   -->  MAX31865
 *    CS: pin 10    -->  CS
 *    MOSI: pin 11  -->  SDI (must not be changed for hardware SPI)
 *    MISO: pin 12  -->  SDO (must not be changed for hardware SPI)
 *    SCK: pin 13   -->  SCLK (must not be changed for hardware SPI)
 * This program is free software: you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation, either version 3 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program.  If not, see <http://www.gnu.org/licenses/>.
#include <SPI.h>
#include <MAX31865.h>
#define RTD_CS_PIN   10
MAX31865_RTD rtd( MAX31865_RTD::RTD_PT100, RTD_CS_PIN );
  Serial.begin( 115200 );
  /* Initialize SPI communication. */
  SPI.begin( );
  SPI.setClockDivider( SPI_CLOCK_DIV16 );
  SPI.setDataMode( SPI_MODE3 );
  /* Allow the MAX31865 to warm up. */
  delay( 100 );
  /* Configure:
       V_BIAS enabled
       Auto-conversion
       1-shot disabled
       3-wire enabled
       Fault detection:  automatic delay
       Fault status:  auto-clear
       50 Hz filter
       Low threshold:  0x0000
       High threshold:  0x7fff
  rtd.configure( true, true, false, true, MAX31865_FAULT_DETECTION_NONE,
                 true, true, 0x0000, 0x7fff );
  rtd.read_all( );
  if( rtd.status( ) == 0 )
    double temperature = rtd.temperature( );
    Serial.print( " T = ");
    Serial.print( temperature, 1 );
    Serial.println(" deg C" );
    Serial.print( "RTD fault register: " );
    Serial.print( rtd.status( ) );
    Serial.print( ": " );
    if( rtd.status( ) & MAX31865_FAULT_HIGH_THRESHOLD )
      Serial.println( "RTD high threshold exceeded" );
    else if( rtd.status( ) & MAX31865_FAULT_LOW_THRESHOLD )
      Serial.println( "RTD low threshold exceeded" );
    else if( rtd.status( ) & MAX31865_FAULT_REFIN )
      Serial.println( "REFIN- > 0.85 x V_BIAS" );
    else if( rtd.status( ) & MAX31865_FAULT_REFIN_FORCE )
      Serial.println( "REFIN- < 0.85 x V_BIAS, FORCE- open" );
    else if( rtd.status( ) & MAX31865_FAULT_RTDIN_FORCE )
      Serial.println( "RTDIN- < 0.85 x V_BIAS, FORCE- open" );
    else if( rtd.status( ) & MAX31865_FAULT_VOLTAGE )
      Serial.println( "Overvoltage/undervoltage fault");
      Serial.println( "Unknown fault; check connection" );
  delay( 3000 );
outsider
You are using a 4 wire (Kelvin connection)? Can you post a wiring diagram?
HowToPostCode & Attachments
jsandbacka
Im using a 2-wire k-type.
Wiread it like this:
Max 31865 -   Leonardo
CS            - pin 10
SDI           - pin 14
SD0          - pin 16
SCK          - pin 15
outsider
#3
Dec 13, 2017, 09:51 pm Last Edit: Dec 13, 2017, 09:52 pm by outsider
"K type"? Is that a thermocouple or RTD? Can you post a link?
jsandbacka
indrawanbp
you can using MAX31865 with RTD not Thermocouple sensor. you can read this  https://www.versasense.com/files/datasheets/MAX31865.pdf
