Topic: did i brick my arduinos? (Read 430 times) previous topic - next topic
jfreise
Dec 14, 2017, 05:34 am Last Edit: Dec 14, 2017, 08:33 am by jfreise
I connected an two Arduino Nanos by the vin and ground ports and it was working for about five minutes until they both stopped uploading.
I was powering by USB
just to be totally clear
vin<--->vin
gnd<-->gnd
DrAzzy
What else was connected to them?
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
jfreise
I had the d2 pins connected to each other but those were the only connections
DrAzzy
What about power, USB? If USB, were they connected to the same or different computer? If external power source, what voltage and how was it connected.
jfreise
I only had one USB connected to my computer and no other external power source
DrAzzy
You probably trashed the voltage regulator on the first nano, because you were drawing power from it's input, but the power was coming into the system on the regulator's output (the USB power does not go through the voltage regulator, as it's already a regulated 5v, and a linear voltage regulator needs an input voltage higher than the output voltage by some amount (a few tenths of a volt on really nice LDOs, up to 2v for some older models) - So to run at 5v, when supplied by USB, the USB power is connected after the regulator. Thus any voltage on Vin is coming backwards through the regulator via it's internal diode. These diodes are not normally meant to carry continuous current (as this won't happen in normal operation); you probably burned it out.
If you want to power two nano's off of one USB connection, connect the 5v pins, not the Vin pins.
The nano not plugged into USB is probably fine. The one that was plugged into USB is probably usable, but without the onboard voltage regulator (so you can't supply it via Vin)
jfreise
#6
Dec 14, 2017, 11:59 pm Last Edit: Dec 15, 2017, 12:05 am by jfreise
Oh okay this makes sense, for future reference if I wanted to power two Arduinos off of an external power, say 12 volts, then would I connect the vin's?
Or would I connect the external to vin and then the 5 volts together
