Right. Back to this again
Happy to take advice from anyone, but particularly hope TonyWilk will contribute what he learned from his trials.
But first, start with what I've got.
1. Acrylic pole approx 30mm diameter, 1m long.
2. Layer of vinyl with design cut into it wrapped around 1. Above. Design is about 70 cm long.
3. Copper mesh 1m Wide, single wrap about 12-15 cm, cast onto pole in clear epoxy resin over the top of the vinyl design
For those who have read backi switched to the mesh becaus3 the copper foil is sold and blocks light. The meshallows light to passwhich mean when puttin LEDs in the tube, the design is still visible.
I know I need to make two triangul plates from the meshplan. I intend to do this by cutting them in-situ through the epoxy in which they are bonded. This should avoid any movement and allow good accuracy and hopefully the cuts will be filled back in with a last wrap of 80gsm fibreglass weave in a polyester resin.
My question surrounds your "driver" line.
My copper mesh is a single wraparound on the pole. I intend to use tape to mark a single turn "helter skelter" down the pole, which when cut should provide the two triangles. There will be two gaps between the triangles...a straight one where the opposite ends of the wrap of copper meet and the cut "helter skelter" cut
But...where to put the driver line? As I see it I have three options;
1. Inside the pole
2. Outside the pole as a single wire set into the resin in the original straight join
3. Outside the pole as a single wire set into the resin in the helter skelter join.
Which do you think would be best?
I've got some beefy 10M Ohm resistors to try and cut through the resin and gf that will be between the finger/hand and the contact plate.
I'm going to post a video of the lights as they are now. I've a finishing process that renders the design invisible when the LEDs are off...it just looks like a plain black pole. The effect I'm looking for is to sweep a hand over it and have it "magically" appear. From a programming point of view all I have to do is relate the input of the capacitive arrangement to the number of LEDs active in the strip. Ideally I'd like the "resolution" of that relationship to be +/-1...ie one LED on or off at a time...but if it has to be in chunks of 4 or 5, so be it.
I've probably missed out something critical...I'm sure someone will let me know...
