Topic: switch case - multiple outputs with same option (Read 5538 times) previous topic - next topic
GreyArea
Hi all
Just a quick one. If I use a switch...case statement on a variable called "test";
switch (test){
case 1:
//do thing 1
break;
case 2:
//do thing 2
break;
case 3:
//do thing 2
break;
as you'll see the result of test being either 2 or 3 results in the same action. Is there a way to enter multiple outputs for a single case, eg
case 1,2:
or similar?
PaulS
The Arduino supports a range option:
   case 1...2:
There is NO way to have one case statement handle discrete values that are not consecutive (i.e. 3 and 7).
groundFungus
#2
Dec 19, 2017, 02:24 pm Last Edit: Dec 19, 2017, 02:25 pm by groundFungus
No, not that way.  The only way that I know is to set a range of values in the case using ellipses.
This will trigger the case on either 2 or 3.  But the range must be inclusive (contiguous?).
int test = 3;
  switch (test)
    case 1:
      Serial.println("thing 1");
      break;
    case 2 ... 3:
      Serial.println("thing 2");
      break;
Paul beat me too it, but I will post my example.
gfvalvo
#3
Dec 19, 2017, 02:24 pm Last Edit: Dec 19, 2017, 04:11 pm by gfvalvo
But, multiple case statements can execute the same code:
switch (test) {
    case 1:
      //do thing 1
      break;
    case 2:
    case 3:
    case 13:
    case 99:
      //do thing 2
      break;
    case 11:
    case 21:
      // do thing 3
      break;
    default:
      break;
No technical questions via PM. They will be ignored. Post your questions in the forum so that all may learn.
econjack
I kinda like the fall-through option gfvalvo shows because you can add comments about each case if you wish.
groundFungus
And now I know a new way,  Thanks, gfvalvo.
GreyArea
Hmm...does the fall through option have to be in numerical order?
PaulS
No.
