Crossroads
Nice to see someone else using wire wrap - a much underestimated technique.
As I sit here, in front of me, I have a wire wrapped XBee on an FR4 perf board. With 20 pins on the XBee, It looks like a rats nest, but it works and no unwanted capacitance. Four reels of 30-guage Tefzel coted wire and an original OK wrapping tool. And dead easy to correct.
Male PCB header pins make great wire wrap pins. I recently found the "Manhattan" style of PCB work. That is a labour of love, but still favoured by the die-hard RF guys.
Ref the hydrochloric acid and hydrogen peroxide, these are getting trickier to get in the UK thanks to them being used for less useful things than PCBs - in a recent terrorist attack, the bomb-maker had been round a lot of hair-dressers buying up the high strength peroxide and I understand that HCl gets used for cocaine purification.
Being a bit more resourceful, you have to look further afield and 32% HCl is still available as a drain cleaner in some hardware shops, other than that, the building trade use it to clean mortar off brickwork.
Nitric is nasty, but not half as nasty when you mix 3-parts HCl to 1-part nitric and end up with aqua regia, the only acid I know that dissolves gold. The one I respect the most though is Hydrofluoric.
