I used an old atx from an old computer to make my own cheap bench power supply and it works fine.
I wanted to add an adjustable voltage output, so i followed this schematic.
For R1 i have a 220 ohm resistor and for R2 i have a 10k ohm potentiometer.
So the adjusting of the voltage works however the first half rotation of the potentiometer is very very sensitive and then it reaches about 11 volts and the rest of the turn of the potentiometer does not change the output voltage.
Is there another resistor value needed for R1 maybe to have a less sensitive output and change the output trueout the whole turn of the potentiometer instead of only using the first half?
Hope you could help me out here.
