Topic: How do i measure the maximum current of an AC variable power supply with resetib (Read 2520 times) previous topic - next topic
TECH GEEK
How do i measure the maximum current of an AC variable power supply with an auto-reseting over-current relay???(~8 ampsish) <---this is the topic
yes i know this topic has a long title(i ran out of room too! :smiley-eek: lol )... and no i can not make it shorter even tho i want to :smiley-roll-blue: <---this is snot the topic
As always... Thanks for posting!!!
jackrae
Do you mean "how do you measure the current it is being loaded at"  If so the simplest way is to buy a cheap clamp-on test meter.
If you mean, what can you load it to without causing it to trip, then simply read the rating plate.
The resettable trip is probably a simple thermal device, in which case it will have a non-linear current x time relationship, so the maximum load current for say 1 second is probably twice that for 5 seconds
jack
TECH GEEK
it's a lionel train trainsformer
says:
  • 7.5-V.A.
  • 8-15Volts
  • !!!AC current only!!!
my main question is this...
The 7.5Volt.Amps. is for what voltage? 8V? 15? Both?
and if it is for only one voltage level, what is the maximum Volt.Amps for the other & what will the maximum V.A. be at differant Voltage levels between 8 &15?
retrolefty
Quote
Volt/amps is equivelent to watts if driving a resistive load. And if it's like the old variable transformers then the maximum 7.5 watt rating should apply anywhere between it's variable voltage output. The actual load current (or wattage or V/A) will of course depend of the load resistance being powered by the variable transformer.
TECH GEEK
Quote
i am trying to find the maximum amount of Amps the unit can handle before bad things start happening
i need 5 Amps minumum
retrolefty
Quote
Well I'm afraid you are out of luck using that source for your 5 amps minimum requirment. 7.5 V/A = 7.5 watts
Amps = watts / volts, so at 8vac output you will get .937 amps (and at 15vac output you will have .5 amps) maximum current rating
jackrae
Puting it simply, there's no way you will get 5 amps out of this without also releasing the smoke genie
If you want 5 amps at 8 volts then you need 40 volt-amp
If you need 5 amps at 15 volts then you need 75 volt-amps
simples
The reason that ac power units are specified as volt-amps is because the supplier has no way of knowing what power factor your load will be.  At unity PF volt-amps is equal to watts.  However at reducing power factor the available watts is also reduced since watts is specified at the equivalent unity power factor.
Hence if the unit is specified as 40 volt amps with an 8 volt output then you will always get 5 amps out of it, even if you have a low power factor (inductive or capacitive load) only represent say 20 watts
jack
TECH GEEK
