Topic: 1284p Bootloader w/Arduino as ISP (Read 3559 times) previous topic - next topic
pert
Make sure the baud rate setting in the bottom corner of Serial Monitor matches the value in your Serial.begin().
ron_sutherland
Nice :)
Seria1*.begin() where *= is the number 1 (UART= 1 right?)
the number looks too much like the letter.
also remember the core you are using is
https://github.com/MCUdude/MightyCore/tree/master/avr/cores/MightyCore
I would look it over some and not assume it is the same as the Arduino core.
Also, you are in charge of keeping that hex file, e.g. expect that I will remove that fork at some point.
DrAzzy
He's probably using UART0 (Serial) not UART1 (Serial1) since it sounds like he's talking over the same serial port as he's programmed it with, and the bootloader uses UART0.
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
ron_sutherland
#33
Jan 10, 2018, 11:14 pm Last Edit: Jan 10, 2018, 11:18 pm by ron_sutherland
This is how I made the bootloader hex in the fork of MightyCore on GitHub
https://github.com/epccs/MightyCore/commit/44e84319371771d2231489a72bf72ea239836a76
pert
Also posted at:
https://github.com/MCUdude/MightyCore/issues/75
If you're going to do that then please be considerate enough to add links to the other places you cross posted. This will let us avoid wasting time due to duplicate effort and also help others who have the same questions and find your post to discover all the relevant information. When you post links please always use the chain links icon on the toolbar to make them clickable.
FedorAdarichev
@pert
I apologize, will do on cross-referencing in the future.
@DrAzzy and @ron_sutherland
You are right, I forgot to put the "1", I changed it, and now it works!
@ron_sutherland
I have saved that hex file to my computer and also noted how you made it.
Thank you all!
ron_sutherland
Maybe it would be good to keep that issue open for a little, it would be better If Hans could add the UART=1 option since it does work and he knows how to make such options show up in the IDE.
hansibull
Hi!
Quote
It's not difficult at all to add UART=1 to the boards menu, but I don't think I want that. Some users also wanted a separate menu for the bootloader baud rate, but I didn't implement it. This is to keep the boards menu as simple as possible. Remember, most users are happy with using UART0 with the default baudrate.
I may implement this later, but this require a bit of work in order to make this as elegant as possible.
I'm thinking about adding a parameter like this to select which UART to use MightyCore  boards.txt#L76
MightyCore -  ATmega1284, mega644, mega324, mega164, mega32, mega16, mega8535
Github.com/MCUdude/MightyCore
MiniCore - ATmega8, mega48, mega88, mega168, mega328
Github.com/MCUdude/MiniCore
hansibull
I'm doing some work on the bootloaders. Will integrate them into MightyCore soon. The bootloader repo can be found here: MCUdude Optiboot_flash
