Topic: Robotic arm torque control (Read 945 times) previous topic - next topic
urko_18
Hello everyone, I am an engineering student and I am doing my final career year practices.
In these practices, I have to implement the control of a robotic arm by arduino.
I have already done most of the control, what I have done has been that first, you have to move the robotic arm as you want and meanwhile the program keeps the positions of the motors. Then, once the positions are saved, the robot repeats the sequence of movements that you have made.
What I want now is to control the torque, that is, if at any moment one of the engines passes a certain torque level, the robot have to stop and must go to a position determined by me.
I already have the torque values of each motor at all times, where I need help is to know in what part of the code and how I can put the structure IF / WHILE or whatever to implement torque control in the program.
This is my program code summarized:
Code: [Select]
//first, i obtained the positions of each motor (4)
    regData1 = dxlGetPosition(SERVO_ID[0]); //read and save the actual position
    regData2 = dxlGetPosition(SERVO_ID[1]);
    regData3 = dxlGetPosition(SERVO_ID[2]);
    regData4 = dxlGetPosition(SERVO_ID[3]);
    positionn1[i] = regData1; //Creation movements vector
    positionn2[i] = regData2;
    positionn3[i] = regData3;
    positionn4[i] = regData4;
//once i have done the movements, them i do some comparison to move the robot
    int before_position_1, before_position_2, before_position_3, before_position_4;
    int position1 = positionn1[0];
    int position2 = positionn2[0];
    int position3 = positionn3[0];
    int position4 = positionn4[0];
//initial is the position whrn the sequence starts
    int  initial1 = positionn1[0];
    int  initial2 = positionn2[0];
    int  initial3 = positionn3[0];
    int  initial4 = positionn4[0];
//THE START OF COMPARISONS FOR THE REPETITION OF THE SEQUENCE
//ID1
      if (positionn1[i] < initial1)
        while (positionn1[i] < initial1)
          before_position_1 = initial1;
          dxlSetGoalPosition(SERVO_ID[0], initial1);
          initial1--;
          delayMicroseconds(Speed);
          if (initial1 != before_position_1)
            if (initial1 == position1 + MX_MAX_POSITION_VALUE)
              position1 = initial1;
              turns1++;
              Serial.print("Turns engine 1: ");
              Serial.println(turns1);
            else if (initial1 == position1 - MX_MAX_POSITION_VALUE)
              turns1--;
      else if (positionn1[i] > initial1)
        while (positionn1[i] > initial1)
          initial1++;
              turns1++;
              turns1--;
//THEM, AFTER THIS CODE, SAME CODE COULD BE FOR THE OTHER 3 ENGINES...(changing the varibals of each one)
//ID2
//ID3
//ID4
    Serial.println(" ");
    delay(1000); //Pause between movements
  delay(7000);
go_to_position(pos1_1, pos1_2, pos1_3, pos1_4, pos2_1, pos2_2, pos2_3, pos2_4);//function to return de robot to a resting position
As you can see, it is the same code for the 4 motors changing the varibals of each one, and my question is where I could put the concidition that if a certain torque were exceeded, the execution of the program would stop.
I don´t know what structure i have to use, and neither if i have to put in all the code of each motor or if i can put this condition only one time at the top or at the end...
Many thanks!
Urko.
urko_18
Sorry, I didn´t put in the part of the code the way that I obtain the torque values of the motors:
Code: [Select]
//I ALSO OBTAIN THE TORQUE VALUES OF EACH MOTOR
        regData5 = dxlGetTorque(SERVO_ID[0]);
        regData6 = dxlGetTorque(SERVO_ID[1]);
        regData7 = dxlGetTorque(SERVO_ID[2]);
        regData8 = dxlGetTorque(SERVO_ID[3]);
//ID1
          initial1--;
              turns1++;
              turns1--;
          initial1++;
              turns1++;
              turns1--;
//ID2
//ID3
//ID4
  delay(7000);
PaulS
Code: [Select]
Why do you need regData1, regData2, etc.? Why not just directly store the value returned by dxlGetPosition() in positionnN?
Why isn't positionn a 2D array?
You have WAY too much duplication of data going on. You need to post ALL of your code.
Obviously, you need to get the torque while the arm is moving. That means that you have to determine the torque in the while loops, NOT once before the while loop starts.
urko_18
Thank you for answering!
During this morning I have been reducing the code, and besides what you have told me about regdata1, ... my code now is like this: (Do not listen to the part of the emergency button that is still undeveloped)
Code: [Select]
     Program to control Dynamixel of robotic arm by urko_18
#include <ax12.h> //Include ArbotiX DYNAMIXEL library
int kop = 4; //Cuantity of dynamixel
int SERVO_ID[] = {1, 2, 3, 4}; // ID numbers
int turns1 = 0;
int turns2 = 0;
int turns3 = 0;
int turns4 = 0;
int i, repetitions;
double Speed;
/*****(r = 1; m = 420) (r = 2; m = 210) (r = 3; m = 140) (r = 4; m = 105)*****/ // maximun "m" for differents "r"
int m = 450; //columns
#include <avr/interrupt.h>
#define PULSADOR_EMERGENCIA (PINB&0x02)
int interrupt_state;
  dxlInit(1000000); //start dynamixel library at 1mbps to communicate with the servos
  Serial.begin(9600); //start serial at 9600 for reporting data.
  Relax(SERVO_ID[0]);
  Relax(SERVO_ID[1]);
  Relax(SERVO_ID[2]);
  Relax(SERVO_ID[3]);
  PORTB |= 0x1E;
  PCICR |= (1 << PCIE1);
  PCMSK1 |= 0x1E;
  interrupt_state = 0;
  interrupts();
  Serial.print(F("ID: "));
  Serial.println(SERVO_ID[0]);
  Serial.println(SERVO_ID[1]);
  Serial.println(SERVO_ID[2]);
  Serial.println(SERVO_ID[3]);
  int positionn1[m]; //Matrix of movements
  int positionn2[m];
  int positionn3[m];
  int positionn4[m];
  Serial.println(F("How many times do you want to repeat the sequence?"));
  while (Serial.available() == 0) {}
  repetitions = Serial.parseInt();
  Serial.print(F("repetitions = "));
  Serial.println(repetitions);
  delay(3000);
  Serial.println(F("How fast do you want to repeat the sequence?"));
  Serial.println(F(" 1 = Slow     2  = Normal     3 = Fast"));
  Speed = Serial.parseInt();
  if (Speed <= 0 || Speed >= 4)
    Serial.println(F("You have entered a wrong value"));
    return;
  if (Speed == 1)
    Speed = 1000;
  else if (Speed == 2)
    Speed = 700;
  else if (Speed == 3)
    Speed = 400;
  Serial.print(F("Speed = "));
  Serial.print(Speed, 0);
  Serial.println(F(" microseconds"));
  delay(3000);
  Serial.print(F("Positions vector "));
  Serial.print(F(": ["));
  for (i = 0; i < m; i++) // structure to create columns
    positionn1[i] = dxlGetPosition(SERVO_ID[0]); //read and save the actual position
    positionn2[i] = dxlGetPosition(SERVO_ID[1]);
    positionn3[i]  = dxlGetPosition(SERVO_ID[2]);
    positionn4[i] = dxlGetPosition(SERVO_ID[3]);
    delay(10);
    Serial.print(positionn1[i]); //Display the vector
    Serial.print(F(", "));
    Serial.print(positionn2[i]);
    Serial.print(positionn3[i]);
    Serial.print(positionn4[i]);
    Serial.print(F("; "));
  Serial.print(F("]\n"));
  delay(5000);
  Serial.println(F("The servos will move to the initial position."));
  /***The servos will move according to registered movements***/
  for (int a = 0; a < repetitions; a++) //Repetition of the process (a = number of sequences)
    Serial.print(F("SEQUENCE "));
    Serial.println(a + 1);
    //First, the servos will move to initial position, in order to do the registered movements
    int pos1_1 = dxlGetPosition(SERVO_ID[0]); //Actual servo position
    int pos1_2 = dxlGetPosition(SERVO_ID[1]);
    int pos1_3 = dxlGetPosition(SERVO_ID[2]);
    int pos1_4 = dxlGetPosition(SERVO_ID[3]);
    int pos2_1 = positionn1[0]; //Initial position of the movement (objective)
    int pos2_2 = positionn2[0];
    int pos2_3 = positionn3[0];
    int pos2_4 = positionn4[0];
    go_to_position(pos1_1, pos1_2, pos1_3, pos1_4, pos2_1, pos2_2, pos2_3, pos2_4); //Function that moves the robot to the initial position
    Serial.println(F("Now the servos will do the registered movements."));
    delay(2000);
    //Now, they will move through the registered positions
      //ID1
      if (positionn1[i] != initial1)
        int next_pos_1 = 1;
          next_pos_1 = -1;
        while (positionn1[i] != initial1)
          initial1 += next_pos_1;
              turns1++;
              Serial.print(F("Turns engine 1: "));
              turns1--;
urko_18
he does not let me put all the program sorry ... this is the continuation:
Code: [Select]
     //ID2
      if (positionn2[i] != initial2)
        int next_pos_2 = 1;
        if (positionn2[i] < initial2)
          next_pos_2 = -1;
        while (positionn2[i] != initial2)
          before_position_2 = initial2;
          dxlSetGoalPosition(SERVO_ID[1], initial2);
          initial2 += next_pos_2;
          if (initial2 != before_position_2)
            if (initial2 == position2 + MX_MAX_POSITION_VALUE)
              position2 = initial2;
              turns2++;
              Serial.print(F("Turns engine 2: "));
              Serial.println(turns2);
            else if (initial2 == position2 - MX_MAX_POSITION_VALUE)
              turns2--;
      //ID3
      if (positionn3[i] != initial3)
        int next_pos_3 = 1;
        if (positionn3[i] < initial3)
          next_pos_3 = -1;
        while (positionn3[i] != initial3)
          before_position_3 = initial3;
          dxlSetGoalPosition(SERVO_ID[2], initial3);
          initial3 += next_pos_3;
          if (initial3 != before_position_3)
            if (initial3 == position3 + MX_MAX_POSITION_VALUE)
              position3 = initial3;
              turns3++;
              Serial.print(F("Turns engine 3: "));
              Serial.println(turns3);
            else if (initial3 == position3 - MX_MAX_POSITION_VALUE)
              turns3--;
      //ID4
      if (positionn4[i] != initial4)
        int next_pos_4 = 1;
        if (positionn4[i] < initial4)
          next_pos_4 = -1;
        while (positionn4[i] != initial4)
          before_position_4 = initial4;
          dxlSetGoalPosition(SERVO_ID[3], initial4);
          initial4 += next_pos_4;
          if (initial4 != before_position_4)
            if (initial4 == position4 + MX_MAX_POSITION_VALUE)
              position4 = initial4;
              turns4++;
              Serial.print(F("Turns engine 4: "));
              Serial.println(turns4);
            else if (initial4 == position4 - MX_MAX_POSITION_VALUE)
              turns4--;
  delay(5000);
  /****REST POSITION****/
  Serial.println(F("The robot will move to the resting position."));
  int pos1_1 = dxlGetPosition(SERVO_ID[0]); //actual robot position
  int pos2_1 = 3820; //rest position of the robot (the positions of the 4 dynamixel)
  int pos2_2 = 400;
  int pos2_3 = 230;
  int pos2_4 = 2395;
  Relax(SERVO_ID[0]);
  Relax(SERVO_ID[1]);
  Relax(SERVO_ID[2]);
  Relax(SERVO_ID[3]);
  Serial.println(F("END!"));
ISR(PCINT1_vect) {
  interrupt_state = (PINB & 0x02) >> 1;
  Serial.println("EMERGENCY BUTTON!");
//The following function will move the robot to the initial position and to the resting position
void go_to_position(int pos1_1, int pos1_2, int pos1_3, int pos1_4, int pos2_1, int pos2_2, int pos2_3, int pos2_4)
  while (pos1_1 != pos2_1 || pos1_2 != pos2_2 || pos1_3 != pos2_3 || pos1_4 != pos2_4)
    //ID1
    if (pos2_1 < pos1_1)
      dxlSetGoalPosition(SERVO_ID[0], pos1_1);
      pos1_1--;
      delayMicroseconds(800);
    else if (pos2_1 > pos1_1)
      pos1_1++;
    //ID2
    if (pos2_2 < pos1_2)
      dxlSetGoalPosition(SERVO_ID[1], pos1_2);
      pos1_2--;
    else if (pos2_2 > pos1_2)
      pos1_2++;
    //ID3
    if (pos2_3 < pos1_3)
      dxlSetGoalPosition(SERVO_ID[2], pos1_3);
      pos1_3--;
    else if (pos2_3 > pos1_3)
      pos1_3++;
    //ID4
    if (pos2_4 < pos1_4)
      dxlSetGoalPosition(SERVO_ID[3], pos1_4);
      pos1_4--;
    else if (pos2_4 > pos1_4)
      pos1_4++;
PaulS
Code: [Select]
int i, repetitions;
There is NO excuse for one letter global variable names.
Code: [Select]
double Speed;
Speed is populated by a call to Serial.parseInt(). Why is Speed a double?
Code: [Select]
  int positionn2[m];
  int positionn3[m];
  int positionn4[m];
On which Arduino is this code running? 1800 ints won't fit in the SRAM of most Arduinos.
Have you seen a real robot arm move? Multiple joints are moving at a time, so that the end effector follows the desired path. Moving one joint at time, from the current position to the target position is not how a real robot moves. I KNOW that this has been pointed out before.
urko_18
I don´t understand you, but I've already removed the global variable and I have put it in the void setup loop
Quote
Quote
Because its has more than one value, it depends of the number that you put (1,2 or 3), and if i put Speed like Int, the program didn´t run correctly.
I am using the arbotiX-M, so i have space in the SRAM (is almost full) and the porgram run correctly.
Of course I have seen a robotic arm, but in this project the aim is that the arm copies the movements that have previously been made.
My doubt remains in how can I do and where can I do the control of the torque.
Urko.
slipstick
From what little of your code you have posted it looks like you are only reading the torque of each motor after all the movements have been completed and the motors have stopped moving. How does that tell you anything useful?
Steve
PaulS
Quote
The FIRST thing you need to decide is WHEN you plan to control the torque. Once you know that, where is trivial.
Of course, you are ASSuming that you can get from the joint angle condition where over-torque happens to some resting position without additional over-torque happening. I've got some news for you, and it isn't good news.
urko_18
Quote
Code: [Select]
This allows to my to have the values of the torque all the time, so i can and i have to use when it is moving.
Quote
My intention is to control the torque when the robot is repeating the sequence that I have marked.
Quote
Yes indeed, I had already thought about it, so perhaps my idea is that when the torque limit is exceeded, by using of this command:
// TorqueOn (SERVO_ID
// TorqueOn (SERVO_ID [1]);
// TorqueOn (SERVO_ID [2]);
// TorqueOn (SERVO_ID [3]);
The motors will stop, and once they are stopped, I will send the robot to the resting position by using the SetPosition command.
Urko.
slipstick
Code: [Select]
Except those lines aren't in your latest "complete" code because you seem to have taken all reference to anything to do with "torque" out of it. This is far too confusing for me.
Steve
PaulS
Quote
The C++ language doesn't have a when statement, so looking for one in your code would be a waste of time.
I suggest that you mean while the robot is repeating the sequence. I suggest, too, that that is far too broad a scope. It is NOT "while repeating the sequence" that matters. It is "while moving a joint from one position to another". And THAT is easy enough to find in your code. It happens in 4 places, which is three too many.
There should be a function, moveJoint() that takes the joint (number/instance), the from value, and the to value, and moves the joint from here to there, monitoring the torque each step of the way. That function should return a value, defining whether the torque was exceeded, or not. If it was, the program needs to break out of the for loop that is iterating the moves AND out of the for loop that is iterating the number of times to repeat the sequence.
