Topic: Problem with first configuration (Read 612 times) previous topic - next topic
Simgy
Hello,
I recently bought an MKR FOX 1200 arduino card, I followed the steps for registration on the SigFox server ans that's what I get:
Code: [Select]
MKRFox1200 Sigfox first configuration
SigFox FW version 2.3
ID  = XXXXXXXXXX
PAC = XXXXXXXXXXXXXX
Module temperature: 26.00
Register your board on https://backend.sigfox.com/activate with provided ID and PAC
Type the message to be sent
I can not connect to the network or send/receive messages.
Have you ever encountered this problem ? And how to fix it ?
Thank you for your help,
aureleq
Hi Simgy,
Have you typed any hex payload in the Arduino Serial Terminal?
You should have other logs in the terminal and see the LED blinking on the board.
Which location are you based?
Aurelien
