You need to identify the wires on that particular servo one wire is + one is ground - and the third wire is signal. If you are using a different servo do a google on its part numbers and find its data sheet tells you which wire is what. If wires are too big for breadboard you have to improvise wrap the ends around some wires that do. The longer wires that come in the kit. If servo wires have soldered ends you need to cut and strip to be able to twist around another wire.
