Topic: Arduino Due and attachInterrupt (Read 1 time) previous topic - next topic
maximej
I have a big problem only with my attachInterrupt on arduino Due.
When i add this line :
Code: [Select]
attachInterrupt(6, message, FALLING );
The message function is directly called even if I use other operating mode like LOW, RISING, etc
I tried my code on Arduino MKR1000 and i don't have this problem.
I give you the code below :
Code: [Select]
int val = 0;
  delay(2000);
      Serial.println(digitalRead(6));
  pinMode(6, INPUT_PULLUP);
 attachInterrupt(6, message(), FALLING );
    Serial.print("LOOP:");
    Serial.println(val);
    delay(100);
    val++;
void message()
    Serial.print("INT:");
Do you have any solution ?
ard_newbie
#1
Jan 24, 2018, 01:42 pm Last Edit: Jan 24, 2018, 01:45 pm by ard_newbie
It might be due to EMI on pin 6 seen as a falling edge. Do you have a pull down or pull up resistor on this pin ?
ard_newbie
Don't use the weak internal pullups, use external pullup résistors like 1KOhms or more.
GolamMostafa
#3
Jan 25, 2018, 06:25 pm Last Edit: Jan 25, 2018, 07:29 pm by GolamMostafa
My experiment also reveals that the MCU is interrupted once during the execution of this instruction: attachInterrupt(digitalPinToInterrupt(6), message, FALLING);.
One may proceed to program the interrupt using ASF Strategy in order to make an authentic declaration that the above-mentioned instruction is really not compatible with DUE though it works fine with UNO.
Help is being sought to get the link for ZIP version of the asf.h file.
maximej
i tried on different pin but there are the same problem on each pin.
and using external pullups don't solve the problem.
In fact it's a software problem.
ard_newbie
This snippet works as expected (I hook a pull_up resistor on pin 6 = PC24). I tested it with a button switch without a debounce( there should be a debounce either software or hardware):
Code: [Select]
// Hook a pull-up resistor of 1K or more between pin 6 and 3.3V
volatile boolean Flag;
  Serial.begin(250000);
  pinMode(6, INPUT);
  PIOC->PIO_ISR;                    // Clear status register
  NVIC_ClearPendingIRQ(PIOC_IRQn);  // Clear pending ISR
  attachInterrupt(6, message, LOW);
  if ((Flag == true)){
    Serial.println(" pin 6 is low ");
    Flag = false;
void message()
  Flag = true;
GolamMostafa
Unfortunately, the setup of Post#5 is not working in my case!
