Topic: Flashing LED with Modulo? (Read 1 time) previous topic - next topic
Kiwi_Bloke
I recently found some code that flashed an LED using a Modulo command (I think it was Modulo?). I liked it because it was simple and didn't require a "high delay low delay" series to run.
Does anyone have an idea where to find the code?
Thanks in advance I will save it this time if I can find it again.
UKHeliBob
Did the code use delay() or millis() ?
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
TonyWilk
Er... there's the 'modulo' operator: % which gives the remainder after division
So this is possible, but maybe a bit cryptic:
Code: [Select]
for( int i=0; i<50; i++ ){
 digitalWrite( LED_BUILTIN, i % 2 );
 delay( 500 );
Yours,
  TonyWilk
Kiwi_Bloke
I think it used delay but I will use millis when I use it in a program
Kiwi_Bloke
Code: [Select]
 delay( 500 );
Yours,
  TonyWilk
No it was much simpler than that but thanks, I should have saved it when I found it the first time
GrooveFlotilla
Here's a hint - try using the modulo operation on the value returned by the millis() function.
Some people are like Slinkies.
Not really good for anything, but they bring a smile to your face when pushed down the stairs.
TonyWilk
You have me intrigued now...
How about this:
Code: [Select]
digitalWrite( LED_BUILTIN, millis() >> 8 & 1 );
//or
digitalWrite( LED_BUILTIN, millis() % 500 > 250 );
Yours,
  TonyWilk
outsider
#7
Jan 25, 2018, 11:29 am Last Edit: Jan 25, 2018, 11:39 am by outsider
Something like this?
Code: [Select]
 bitSet(DDRB,5);
 int interval = 1000, pulseLen = 30;
 bitWrite(PORTB,5,millis() % interval <= pulseLen);
wilfredmedlin
I may be having a thicker day than normal, but where does modulo come in to blinking an led?
Keep Calm and call 0118 999 88199 9119725...... 3
outsider
#9
Jan 25, 2018, 01:41 pm Last Edit: Jan 25, 2018, 01:50 pm by outsider
1:  Let's say, at this moment, millis() = 5000 (5 seconds since startup), millis() % 1000 = 0.
2:  millis() % 1000 = 0  and is < 30, so LED = ON.
3:  31 mS later, millis() % 1000 = 31 and is NOT < 30, LED = OFF.
4:  969 mS later, millis() = 6000 (6 seconds since startup), back to line 2.
UKHeliBob
Useful when an asymmetric blink is required
Code: [Select]
unsigned long periods[] = {1000, 5000};
byte counter;
const byte ledPin = 13;
  pinMode(ledPin, OUTPUT);
  delay(periods[counter % 2]);
  counter++;
  digitalWrite(ledPin, !digitalRead(ledPin));
Easy to extend
Code: [Select]
unsigned long periods[] = {1000, 5000, 500, 200};
byte counter;
  delay(periods[counter % 4]);
  counter++;
wilfredmedlin
Ah ok, so the remainder is the index: cunning, thanks.
Funnily enough, I implemented a blink without delay the other day with a short on, short off, short on, long off to give like a heart beat duf-duf-pause, duf-duf-pause, which I run in the background on L13 as a sign-of-life.
This will make that a lot neater.
westfw
Something like this, perhaps?
Code: [Select]
  if (millis() % 1000 == 0) digitalWrite(13, HIGH);  // turn on at the one-second marks
  if (millis() % 1000 == 100) digitalWrite(13, LOW); // turn off at the 1.1s marks
  // other (non-delaying) code
Note that "%" (modulus, remainder, etc) is a relatively computationally complex operation.
boolrules
I hate using millis( ) for timing.  I use the following scheme especially for LEDs. The count at 1/60 of a second is
like a 60fps movie.  You can generate any LED changes that your eyes can resolve.
Code: [Select]
// before setup( )
byte     iCount   = 0;
byte     iFrame   = 0;
long int lastTick;
// in setup( )
lastTick = millis( );
// in loop( )
// generate a 1-second iCount to 60
// never mess with willis( ) in your code after this
// loop( ) has to run < 17mS worst case. (If necessary, lengthen time between iCount)
if( millis( ) - lastTick >= 17 ) {
    if( ++iCount >= 61 )    // iCount runs 1 - 60...
        iCount = 1;         // ...about 1/60 of second
    iFrame = 1;             // iCount has changed
void example( ) {
    // about half second on half second off:
    if( iCount == 1 )       digitalWrite( LEDpin, HIGH );
    else if( iCount == 30 ) digitalWrite( LEDpin, LOW );
void another( ) {
    // about 5 flashes/sec:
    if( !(iCount % 6) )   digitalWrite( LEDpin, ~digitalRead( LEDpin ) );
if( iFrame == 1 ) {     // so you don't call functions unless you know iCount has changed
                        //    or also test iCount before calling any function.
    iFrame = 0;         // clear immediately
    example( );
    another( );
TonyWilk
I like it!  So much processing burnt on blinking a LED :)
Maybe there should be a list of "Ways to blink an LED that you are not advised to suggest in an interview"
Yours,
 TonyWilk
