Topic: Flashing LED with Modulo? (Read 1 time) previous topic - next topic
aarg
FWIW
Code: [Select]
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, millis()&2048);
  ... with a transistor and a large sum of money to spend ...
Please don't PM me with technical questions. Post them in the forum.
TonyWilk
FWIW
Code: [Select]
Almost, but no cigar.
The parameter has to be a zero or nonzero byte; you could make that truthy: (millis&2048)==0
Yours,
 TonyWilk
aarg
Yours,
 TonyWilk
Didn't you mean
Code: [Select]
(millis()&2048)==0
westfw
Quote
So much processing burnt on blinking a LED
well, with a little adjustment it could become pretty good...
If the idea is to just "flash the led once in a while to show we're still alive", you can get a way with optimizations:
Code: [Select]
  if ((millis() & 1023) == 0) digitalWrite(13, HIGH);  // turn on at the ~ one-second marks
  if ((millis() & 1023) == 100) digitalWrite(13, LOW); // turn off at the ~1.1s marks
(bitwise AND with one less than a power of two is equivalent to modulus with the power of two.)
wilfredmedlin
I was about to complain that code doesn't work, when I realised I hadn't pinMode'ed as OUTPUT ;) . I like to have proof of life in sketches, so that is now my way to do it.
Keep Calm and call 0118 999 88199 9119725...... 3
Kiwi_Bloke
Well I have learned so many options to try, but the code I found did something at bit level, inverting 0 and 1 somehow.
Thank you every one that has commented and posted ideas, it has been great to see all the suggestions and thought processes working to help.
westfw
Code: [Select]
static byte ledstate = 0;
if ((millis() & 1023) == 0) digitalWrite(13, (ledstate^=1));  // invert the LED every ~1 sec
Or
Code: [Select]
if ((millis() & 1023) == 0) digitalWrite(13, ! digtialRead(13));   // invert the LED every ~1 sec
TonyWilk
Didn't you mean
Code: [Select]
(millis()&2048)==0
touché :)
Yours,
 TonyWilk
