Topic: Nema 17 + DS3231+ A4988+ Arduino UNO (Read 475 times) previous topic - next topic
sinan
Hello there
I need to turn the Nema 17 motor by 360 degrees per minute. I searched on the forum, but I could not reach a conclusion. The motor will settle for seconds hand. Is the DS3231 necessary for this work? Continuous motion is not important.  It is enough to turn 360 degrees within 1 minute.  The codes I tried were not helpful. What kind of code should I write?
Thank you.
artisticforge
Hello there
Thank you.
In the event that I may need to replicate your environment I ask the following questions:
Are you using an original Arduino UNO or a clone of the Arduino UNO?
What version of the Arduino IDE are you using?
What operating system are you using?
Linux, MacOSX, MS Windows, other?
Do you have a wiring diagram?
Do you have a Schematic?
How are you driving the Nema 17 stepper motor?
the motor is driving the seconds hand of a clock?
360 Degrees / 60 seconds == 6 degrees per second
easily doable with an Arduino UNO.
Robin2
Two or three hours spent thinking and reading documentation solves most programming problems.
artisticforge
