Topic: Problem reading Batt from MKRFOX (Read 770 times) previous topic - next topic
ecabanas
HI,
I'm using a MKRFOX1200 to monitor some values and batt level.
To measure the batt level I'm using this code:
Code: [Select]
int sensorValue = analogRead(A0);
  // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
  float sbatt = sensorValue * (5 / 1023.0);
But the results are not true. I connect a battery to the screws and I measure the voltage with a voltimeter and the result is 3.2V.
Using this script the result is 2.98, anybody knows why?
Thank's in advance
Eduard
