Topic: Trouble understanding some arithmetic in my code for an EC sensor A1003v1  (Read 489 times) previous topic - next topic
BearManTooth
I tried to contact the distributor but there contact tab doesn't seem to be functional
Can some one please help me understand the values used to convert from analogInPin to analogRead
My end goal is to convert this EC value into PPM
Code: [Select]
const int analogInPin = A1;
const int analogOutPin = 9;
int sensorValue = 0;
int outputValue = 0;
sensorValue = analogRead(analogInPin);
  // map it to the range of the analog out:
                                                               outputValue = map(sensorValue, 0, 1023, 0, 5000);
  // change the analog out value:
  analogWrite(analogOutPin, outputValue);
  // print the results to the serial monitor:
  Serial.print("sensor = " );
  Serial.print(sensorValue);
  Serial.print("\t EC = ");
        Serial.println(analogRead(1)* 5.00 / 1024, 2);
  // wait 10 milliseconds before the next loop
  // for the analog-to-digital converter to settle
  // after the last reading:
el_supremo
You've used code tags correctly before. How did you get it so wrong this time?
And changing the text colour to yellow is a disaster. It's unreadable.
Pete
Don't send me technical questions via Private Message.
BearManTooth
lol yeah I noticed and im not sure how I screwed that code tag up so hard.
el_supremo
Where did you get that code from? It doesn't compile, so maybe the conversions are rubbish.
This bit doesn't make sense:
Code: [Select]
it is converting the sensor value from a range of 0-1023 to a range of 0-5000 and then outputting that value with analogWrite. The problem is that analogWrite only takes an 8-bit value on 328-based Arduinos. So which Arduino is this written for?
Pete
wvmarle
For NaCl solutions, EC 1 mS/cm is approx. 500 ppm.
For typical hydroponic fertiliser solutions, EC 1 mS/cm is approx 700 ppm.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
