Topic: Temperature Sensor advice  (Read 645 times) previous topic - next topic
1druid1
Hi All
I am looking to build a device that will let me test the temperature of products inside a fridge and freezer.
Can anyone recommend good temperature sensors for this?  I know I can buy an infrared thermometer and save the hassle but this will be the start function of a multi tool proof of concept I am desining , the sensor needs to be accurate,  +/- 1 degree Celsius.  It also has to be able to deal with liquid if it's a touch based sensor.
Cheers
Druid
groundFungus
wvmarle
You plan to actually stick probes into those products? An IR sensor would read only the surface temperature of a product, which may be quite different from the bulk of the product.
Anyway, the easiest is to use wired sensors, and just lead the wires through a hole in the door or the side of the fridge.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
jremington
MorganS
Why make a hole in the fridge? The wires can be thin enough that the door seal will close adequately.
"The problem is in the code you didn't post."
groundFungus
Quote
That is how my freezer monitor is done.  3 conductor, 28 AWG flat cable causes no significant leakage.
TomGeorge
Will the sensor be coming in contact with food?
If so you will need food grade sensors, specifically designed for the food industry.
I think you will find some health regs about it.
Tom.. :)
Everything runs on smoke, let the smoke out, it stops running....
