zoomkat:
Some test code you can try. Make sure the arduino IP address matches the format used by your router and that IP address is not already used.
//zoomkat 11-13-10
//simple ethernet client test code
//for use with IDE 0021 and W5100 ethernet shield
//modify the arduino lan ip address as needed
//open serial monitor to see what the arduino receives
//push the shield reset button to run client again
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 102 }; // Arduino IP address
byte server[] = { 208, 104, 2, 86 }; // zoomkat's web site
Client client(server, 80);
Ethernet.begin(mac, ip);
Serial.println("starting simple arduino client test");
Serial.println("connecting...");
if (client.connect()) {
Serial.println("connected");
client.println("GET /~shb/arduino.txt HTTP/1.0");
client.println();
Serial.println("connection failed");
if (client.available()) {
char c = client.read();
Serial.print(c);
if (!client.connected()) {
Serial.println("disconnecting.");
Serial.println("==================================");
Serial.println("");
client.stop();
for(;;);
Thank you, though it doesn't seem to work, here is the output from the serial monitor:
connecting...
connection failed
disconnecting.
I rebooted my router and it had no effect. All other devices can access the internet just fine...
